X1000
    Posts: 10977 from 2003/5/22
    > The tabor driver may point the way to fixing the X5000 driver.
    I doubt it as the P1022's eTSEC/VeTSEC is less complex than the P5020's DPAA with dTSEC.
  • »02.03.18 - 23:14
    > I suppose I got the wrong idea from that posting then.
    ...or I‘m reading the word 'suggestion' wrong ;-)
  • »02.03.18 - 23:17
    xilinder
    Posts: 39 from 2018/2/1
    IBM is printed on my PA6T, but maybe TI did manufacture it(?).
    I'm not saying it was poorly designed, just that the design was unimaginative.
    Why not another southbridge type chip with some different functions for example.
    When I say the SE/XE are not that much different from the X1k I'm speaking of functionality not 10 years of technological advancement.
    Does it have a PPC CPU?
    Does it have card slots?
    Does it have a southbridge?
    Etc.
    Well, anyway that's why I prefaced my post with IMHO, and that's worth about nothing.
    Too bad the PA6T disappeared. Rotten luck.
  • »03.03.18 - 12:55
    That‘s interesting. I have seen many photographs of PA6T-1682M chips and all looked like this (with P.A. Semi logo and name):
    http://www.amigaos.net/sites/default/files/styles/large/public/pasemi.jpg
    Can you make a photo of yours and upload somewhere?
    Which other southbridge chip with what different functions that was available a decade ago are you imagining?
    Me neither. I was speaking about the quality of the board design and the quality of certain components. Nothing to do with technological advancement.
    Yes, of course it does. Using a non-PPC CPU would have made it unsupported by OS4, which wouldn‘t have made much sense for a board specifically designed with running OS4 in mind, would it?
    Yes, of course it does. The users are supposed to be able to expand the functionality of the computer, after all.
    Yes, because the PA6T is just a minimal SoC and doesn’t provide the required I/O functionality except Ethernet, opposed to Cyrus‘ P5 or Tabor‘s P1. Another possibility would have been to use a dedicated chip for each I/O function, which was the original plan, but Varisys ultimately decided for an all-in-one package as the cheaper and technologically superior solution.
    As I see it, there were no alternatives to incorporating a PPC CPU and card slots. And it made good sense to incorporate a southbridge chip like the SB600, given the restrictions of the PA6T.
  • »03.03.18 - 15:54
    Posts: 4897 from 2009/1/28
    Yes, we pretty much knew the SB600 was the likely choice for the X1000, before the full specs were released (in fact it was spotted in photos before Aeon released those specs).
    Andreas and I had been discussing a 8640/8640 based system and the SB600 looked like the only well documented Southbridge that could be used as a substitute for the ULi Southbridge that Freescale had been using on their evaluation boards.
    I actually have a notebook filled with notations for the pin equivalencies between the SB600 and the ULi Southbridge.
    Basically, at the time the SB700/750 wasn't well documented, and the latter chips hadn't been introduced yet.
    The SB600 was a really good option. I liked it as it was fully documented, available, and had agood feature set.
    What else would have been used at the time of development?
  • »03.03.18 - 16:36
    xilinder
    When I pull the cooler off I will, but it might be awhile.
    I have not dug into what the various southbridge, specialty chips contain. Perhaps one of them has more easily supported network or sound or something(?).
    If for example one was connected to one or two PCIe lanes it might have provided two more PCI slots for lower demanding add in cards splitting the load on the other chip.
    Or also connect the XMOS chip to the second 'southbridge' instead of the localbus.
    Speaking of XMOS, it sure would have been nice if its xena slot were PCI.
    I do like the PA6T. Its kind of a desktop oriented POWER series chip.
    I guess cost was a big factor.
  • »03.03.18 - 17:12
    Nah, the PA6T isn't an SOC like the P5020 (where networking is built into the processor).
    And the X1000 uses a standard PC Southbridge and NIC.
    The only thing that might have made support easier is using a more common NIC.
    Obviously the controller built into the PCI cards was fairly easy to support.
    And from the POV of necessity, only the Tabor with its P1022 cpu really must have a driver for the on chip NIC, because that system has limited expansion capabilities.
    The X1000 and X5000 can easily use plug in network or wireless boards.
  • »03.03.18 - 18:18
    The M1575 offers Ethernet, but as Jim said, it wasn‘t available anymore when the Nemo board was designed.
    You previously bemoaned that with a PCI NIC connected to the SB600, the network traffic would have to go through the southbridge. How would that be different with a southbridge incorporating the Ethernet controller? And what‘s wrong with the SB600‘s audio?
    As said, all of the PA6T’s PCIe lanes are in use, so dedicating some to PCI would have impacted the PCIe capability. Also, two more PCI slots would have required the space of at least two of the PCIe slots, resulting in only few PCIe expansion options. I don‘t think that would have been welcomed by potential customers. And I believe two legacy PCI slots should suffice.
    Btw, a southbridge chip is extreme overkill just for providing PCI slots. A mere PCIe-to-PCI bridge chip (as used on Cyrus Plus) would do.
    A-Eon seemed very fond of Xena’s tight integration with the PA6T.
  • »03.03.18 - 20:57
    The PA6T has a GbE controller, which is precisely what‘s supported by Linux with no problem and by OS4 with a non-public beta driver. That‘s why normal OS4 users have to use a supported NIC in a PCI(e) slot.
    Nemo has only one on-board NIC, and that‘s the GbE one built into the PA6T.
  • »03.03.18 - 21:15
    I wasn't aware of that feature of the PA6T, but they could have incorporated a separate NIC.
    Still, the network card seems like an entirely adequate solution.
  • »04.03.18 - 04:47
    It also has 10GbE, btw.
    Yes, in that case they would surely have used an OS4-supported GbE NIC like the RTL8169.
  • »04.03.18 - 09:38
    Posts: 2706 from 2006/3/21
    Do you happen to know what the limitations, and/or problems are with the "non-public beta driver" for the PA6T's built in NIC are, which are keeping it from being released as the default NIC to use while running AmigaOS4.1FE? IIRC, that beta driver is included on one of the AmigaOS4.1 installation CD/DVD's, but is not included as the default driver, and must be installed, or configured manually, if the user wants to try out the beta driver for the PA6T's onboard NIC. I would like to try it out the next time I decide to turn on and use my X1000 (which I must admit, has seen very little use for a long time, but now that I have updated my Hollywood programming language to the latest versions, I am hoping to use my X1000 several times a week, to learn more about programming with Hollywood).
  • »22.03.18 - 16:34
    > "non-public beta driver" for the PA6T's built in NIC are [...]? IIRC, that
    See comment #981. What's linked from there is all I know.
  • »22.03.18 - 20:52
    >>> Cyborg [...] was never sent another Nemo board to complete it.
    >> If you take the time to read his posting to the end you‘ll find
    >> that he writes he was sent a replacement by A-Eon in 2015.
    > Yes, few years late when he was under heavy x5000 development
    > or similar. This gap to task wait seems to be crucial since there
    > seems to be no one else assigned to task.
    It seems that whenever he retells the story, the time he got his replacement board keeps being 2 years in the past ;-)
    http://translate.google.com/translate?sl=de&tl=en&u=https://www.os4welt.de/viewtopic.php?p=37316%23p37316
  • »12.01.20 - 16:55
