X1000
    Posts: 80 from 2017/9/10
    read the costel post make me really happy with my choice of No More A-eon in My home...
    now i have a micro A1 the true real amigaone machine, the quad g5 the best powerpc desktop machine with the hope of morphos on it... and a threadripper 1950x that will make me happy emulating x5000
  • »23.01.18 - 13:08
    >micro A1
    Ugh, flawed Northbridge.
    A Pegasos II maybe, any early AmigaOne, no thanks.
  • »23.01.18 - 14:40
    Posts: 12406 from 2003/5/22
    ...that wasn't allowed to be officially called an "AmigaOne" ;-)
  • »23.01.18 - 14:41
    Jim wrote:
    >micro A1
    no the pegasos2 is the best ng ever made . amen
  • »23.01.18 - 14:53
  • vox
    vox
    Posts: 616 from 2003/11/24
    > Cyborg [...] was never sent another Nemo board to complete it.
    If you take the time to read his posting to the end you‘ll find that he writes he was sent a replacement by A-Eon in 2015.
    Yes, few years late when he was under heavy x5000 development or similar. This gap to task wait seems to be crucial since there seems to be no one else assigned to task.
  • »23.01.18 - 18:01
    Let's face it, the situation is pathetic. The more I compare the X1000 to the X5000/20, the greater my appreciation for the former is.
    Not a bad little system.
    Not as powerful as a Quad G5, but still pretty cool.
    However, since we aren't likely to see MorphOS on an X1000 or a Quad G5...and things seem pretty terminal for big endian PPCs...it is what it is.
  • »23.01.18 - 19:37
  • vox
    vox
    PA Semi has awful MIPS per Mhz ratio degrading its 1.8Ghz nominal rating, but when used dual core, with FPU instructions, it has fast mem and SATA and board is quite expandable. Its bi-endian arhitecture, 64-bit, G5 class overall in all but integer performance. Too bad its not that easy to add support for another mobo with no financial stimulation (MorphOS). Its quite enjoyable under Linux, but sigh, change to Southern Island cards created no 3D problem under Linux, rendering many installations unusable incl. X1000 Ubuntu Remix sold by AEON. In the end there is no system that completely use it, and CFE is ... built for routers and should stay there.
    saga of wasted computer potential. So contrary to Amiga spirit of squeezing maximimum out of it.
  • »24.01.18 - 18:26
    Posts: 2065 from 2003/6/4
    Best way out: Don't look back and welcome spectre/meltdown x64 ;-)
  • »24.01.18 - 19:13
    Yeah, but the system has a nice set of expansion slots backed up by more PCI-e channels.
    And the processor is slightly better than a G4 (as well as being full 64 bit).
    The more I'm learning about the X5000's expansion , the more troubled I am about it's limitations. Then again there's the difference in memory bandwidth.
  • »25.01.18 - 01:34
    "Then again" or rather "furthermore"? ;-)
  • »25.01.18 - 09:52
    Grammatically, you are right to point that out.
    But actually my final comment was a bit recursive.
    I am beginning to think the e5500 and e6500 cores may not be reaching anything close to their supposed memory bandwidth.
  • »25.01.18 - 11:14
    If the cause of the memory performance issue is in the SoC, I think it's in the SoC's 'uncore' (memory controller) rather than its core.
  • »25.01.18 - 13:02
    I'd like to see some bandwidth figures for the T10xx CPUs when interfaced with DDR4.
    The DDR3 controller used with other e5500 and e6500 cored CPUs does seem to be the issue.
  • »25.01.18 - 23:32
    I thought the memory bandwidth and speed for the X1000's PA6T, was one of its few advantages, when compared to the older Apple G4 & G5 computers? Or is the PA6T an exception for e6500 cored CPU's, when it comes to memory bandwidth?
    It's probably that I'm not paying attention to this discussion, so I have made an incorrect assumption (again).
    Edit: I probably should have changed "memory bandwidth" above, to read/write speed to RAM.
    [ Edited by amigadave 27.01.2018 - 16:04 ]
  • »27.01.18 - 23:03
    Yep, I think Andreas mentioned this before in response to a similar comment.
    The PA6T in the X1000 was produced by PA Semi and does not use a Freescale core.
    And yes, it's got better memory bandwidth then a G4 (not sure about the G5 though) as well as the e5500 and e6500 based Socs.
    So, even with older DDR2 memory, the X1000's memory controller performs much better than the X5000.
  • »28.01.18 - 01:20
    >"...The contract was signed at the Amiga 30th event in Peterborough, UK in August 2015..."
    Two and a half years and they have not produced a working network driver, and along with De Groot, Mincea is now running Hyperion?
    Guess they are just to 'busy' to complete a contract that has already been paid for. ;-)
    Doesn't bode well for future support of older Aeon products.
    For that matter, do any of the Aeon AmigaOne boards have functioning on-board network drivers (if not under OS4 then Linux at least)?
    And we are complaining about the delay in the release of MorphOS 3.10 to WHAT end again?
    We don't pay for updates, and when our developers committed to projects in the past, they completed them.
    [ Edited by Jim 01.03.2018 - 11:38 ]
  • »01.03.18 - 15:36
    OS4: no
    Linux: X1000/Nemo - yes, A1222/Tabor - probably yes, X5000/Cyrus - currently no
  • »01.03.18 - 21:04
    xilinder
    Posts: 39 from 2018/2/1
    IMHO.
    The PA6T (made by IBM) is under utilized on the X1000. The SB600 does most of the work and moves data to/fro the CPU through a single high speed pipeline. That includes the PCI network card.
    Pretty much the X1k was a 'just-get-it-working' and kick it out the door type of project. I don't blame Trevor for the shortcomings. He is an AmigaNut, but not a hardware guy. If you think about it the X1k is not that much different than the A1SE/XE, which was supposed be a system only to get OS4 working on PPC. A development system, and it was sold as such. Unfortunately the A1XE somehow became the standard base design for all that followed. The XMOS chip has never been supported at a base level. Sad really, looks like the X5000 will follow suit, no innovation, nothing for the hardware enthusiasts, going to do everything in software. Pfffffft! Microsoft.
    Of course you can't blame A-EON for everything when 90% of the squeaky wheels want a dirt cheap Amiga that most of them would not purchase anyway. And if they did they would want the OS for free.
    The X1000 is a very good PPC Linux machine however, and CFE allows you to probe around the hardware and find some interesting undocumented features.
    As my meaningless rants would only fall on deaf ears my X1k now sits in the closet along with other offerings to the Gods-of-technology.
    Perhaps someday............. well, one can dream. :-)
  • »02.03.18 - 14:32
    number6
    Posts: 487 from 2008/8/10
    OS4: no
    Of additional interest:
    from Jamie Krueger
    If I read this correctly, even IF the driver being worked on currently was completed/released it would be (how to say this politely...) a handicapped driver?
    #6
  • »02.03.18 - 16:48
    OS4: no
    from Jamie Krueger
    #6
    Well the Tabor driver HAS to function (since there are no extra expansion slots for a wireless networking card). I suppose you could use a USB adapter, but that is sub-optimal.
    The tabor driver may point the way to fixing the X5000 driver.
    But the X1000 driver is going to be a bit different.
  • »02.03.18 - 19:28
    The PA6T was designed by P.A. Semi (bought by Apple a decade ago) and manufactured by Texas Instruments.
    Hardware-wise, I consider the Nemo board a good design by Varisys, despite the obscure xCORE/Xena stuff. All SerDes lanes of the PA6T have been put to good use and the GbE controller is routed to a PHY and jack.
    You mean the allegedly under-utilized PA6T should do more of what the SB600 does? If so, what tasks would that be?
    These 4 lanes (1 GB/s total) should provide sufficient bandwidth for the SB600 and its controllers (SATA/PATA, USB, audio, PCI). The SB600 doesn‘t support a wider connection anyway.
    If the OS can‘t use the PA6T‘s GbE, a supported PCIe NIC can be used, so that the network traffic doesn‘t have to go through the SB600.
    That‘s certainly not my impression.
    I think it‘s worlds apart, both design-wise and component-wise. The Eyetech AmigaOne (Mai Logic Teron) boards are bug-ridden evaluation boards with questionable components (ArticiaS northbridge and 82C686B southbridge). You can see that Varisys is a professional board design company whereas Mai Logic was not.
    The Eyetech AmigaOne boards were developed by Mai Logic under the Teron moniker as evaluation boards for their northbridge chipsets and for running Linux.
    The AmigaOne SE (Teron CX), yes. The AmigaOne XE (Teron PX) was sold by Eyetech as end-user system, especially after OS4 became available.
    There‘s no way that anything that followed, except the Micro-A1, was based on the AmigaOne XE.
    In my opinion, the biggest problem with the Cyrus Plus board‘s hardware design is its compatibility with both the P5020 and the P5040, which leaves the P5020 halfway under-utilized in terms of SerDes lanes and PCIe controllers.
    http://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=12137&start=97
    Moreover, the X5000 seems to suffer from a severe memory bandwidth problem, caused by either the SoC‘s memory controller or a firmware bug or mis-configuration.
    http://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=11137&start=623
    Huh? :-)
  • »02.03.18 - 20:03
    Only if it was ported from U-Boot instead of Linux, which I don‘t think Hyperion is doing or will do.
  • »02.03.18 - 20:21
    number6
    The suggestion was made to Hyperion to develop the Amiga driver derived from the simpler and smaller Uboot network driver due to the reduced code base from the Linux version.
    Source
    I suppose I got the wrong idea from that posting then.
    #6
  • »02.03.18 - 20:37
