New SAM460EX
    Velcro_SP
    Posts: 929 from 2003/7/13
    [ Edited by Velcro_SP 20.04.2011 - 07:47 ]
    Pegasos2 G3, 512 megs RAM
  • »30.07.10 - 01:17
    Velcro_SP
    [ Edited by Velcro_SP 20.04.2011 - 07:45 ]
  • »30.07.10 - 01:30
    Posts: 12077 from 2003/5/22
    >> And how did it go into the board design if not by adding it?
    > I don't know, you tell me.
    Of course, I will: A chip simply *cannot* go onto a board without someone adding it.
    > This has nothing to do with anything
    That's how you want to make it look now. Seems you already forgot, but you told: "they don't even say "adding". That's clearly what I referred to when asking how a board could have your "dedicated graphics chip" without someone adding it. And because it's not possible to have a chip on a board without someone adding it before it becomes obvious that you stating that your words "don't even say "adding"" is a dummy argument.
    > but then that's typical for you.
    It's typical for you to forget what you had said yourself.
  • »30.07.10 - 02:13
    > The fact that I said chip doesn't mean I suggested putting a redundant
    > PowerVR chip on a 5121e
    You can't put a chip on an MPC5121e, which is a chip itself. In case you are using your fantasy terminology again and really meant a "board with an MPC5121e": How can you possibly have a "dedicated graphics chip" on a board with an MPC5121e and *not* end up having two graphics cores on that board?
  • »30.07.10 - 02:23
    >Your comments haven't raised its IQ any.>
    I am, in no way, concerned about your opinion of my intelligence.
    >I'm aware that chip is a discrete object. This fake point about "chip" and "hardware" is just red herring #26. The fact that I said chip doesn't mean I suggested putting a redundant PowerVR chip on a 5121e anymore than it means I suggested to put one on a fuel-injection system in a Chevy Volt.>
    I had to edit this as I must admit that I'm not sure I understand your point. We weren't discussing engine management systems, we were discussing a board you insist on identifying by its CPU. Further, we were discussing whether or not your posting suggest adding a graphics chip to that board.
    >I didn't say I thought he needed help, I said evidently you think that and evidently that's correct because you're still jumping in there like his loyal echo. Jim, you ought to take off your "AnDreaZ R0xx0rs" t-shirt for a few minutes and start thinking for yourself.>
    Actually, I'd pledged no to involve myself in this any farther. It had become painfully drawn out on all parts. But as you choose to make this personal, I feel compelled to respond.
    With over 30 years of experience in the computer field, I've learned the hard way who to trust and who not to trust. Who to have respect for and who to disregard. Who to take advice and criticism from and who was making pointless, self centered negative comments.
    I'll keep the pro Andreas tee shirt and maybe add one for Zylesea and several other on this (and other) Amiga forums. And I'd add one for my former employer, electrical engineer Ed Gressick (deceased former owner of Delmar Co.) who long ago made me realize that while it was important to listen to others, that it was equally important to consider what they have say and then make up your own mind.
    I'm pretty selective about who I truly take seriously. So far, your arguments haven't lead me to include you in this group. [
    [ Edited by Jim on 2010/7/30 19:43 ]
  • »30.07.10 - 02:54
    You can't put a chip on an MPC5121e...
    I don't know, I must be stupid. That makes sense no matter how often you have to say, so...
    What scares me is the point about video cards. I just got beaten up over this to the point where I've acquiesced to calling these graphics cards (as if any nimrod is going to mistake a TV tuner card as a video card). So, I actually agree with him on this point.
    "There's a fine line between stupid and clever." -- St. Hubbins
  • »30.07.10 - 03:03
    Velcro_SP
    [ Edited by Velcro_SP 19.04.2011 - 15:35 ]
  • »31.07.10 - 11:58
    Velcro_SP
    [ Edited by Velcro_SP 20.04.2011 - 07:06 ]
  • »31.07.10 - 12:25
    Frankly, I was waiting to see how you would respond.
    The long delay signifying more than you'd be willing to admit.
    You could use one paragraph (taken out of a group) as a signature block, but its content would be no less obtuse than most of what you've posted.
    I believe signature blocks are usually used to relay content that is thought provoking or clever. Most of what you've had to say is neither.
    And I'll stop posting my background information as, again, I'm not worried about your opinion on such matters.
    Your misstatement was completely clear. I will not post that content because its been done repeatedly and you fail to acknowledge it.
    Therefore, giving additional points you can analyze and then comment on merely allows you to dismiss your own mistakes and focus on what you perceive as the flaws in those that you think of as adversaries.
    Regardless of my personal history, I can read and understand English. Even when its poorly worded.
    Instead of adding the previously mentioned paragraph as a signature block, why not just add chip? Or you could switch to using that as your ID. Or we could just consider it your unofficial "nickname".
  • »31.07.10 - 16:23
    Velcro_SP
    [ Edited by Velcro_SP 20.04.2011 - 07:04 ]
  • »31.07.10 - 18:13
    > both of those surrounding paragraphs refer specifically not only to 5121e-based
    > platforms but to non-5121e-based platforms: above to Limebooks (which includes
    > X86 models, remember?)
    Let's see:
    "I'd like to see where the software has gone with the Linkbook and LimePC models. All I have to go on is an original Cherrypa1 with an 18-months-old OS that I haven't been able to update."
    The Linkbook, which is a relabeled LimeBook Z9, is MPC5121e based. And while there're indeed x86 based LimePC models, your statement was about "where the software has gone" with them when we just before (see what you responded to with that posting) discussed the (lacking) driver support for both the PowerVR and the AXE core of the MPC5121e. None of the x86 based LimePC models have AXE or PowerVR. In fact, AXE is to date nowhere else than inside the MPC5121e and MPC5123, and the Atom based LimeBook Z10 has Intel GMA 950 graphics. So I conclude: This paragraph is solely about MPC5121e based hardware.
    > and below to ACube PPC computers.
    Let's see:
    "I don't mean to zero in on the 5121e as the only thing, but really even given the uncertainty it seems much more established to me than this other low-wattage, small stuff. I like the ACube computers too, but they are somewhat larger and higher wattage."
    Here you are mentioning ACube as a side note, yes. But your main point is clearly about the MPC5121e being superior over other solutions, which are (in your opinion) either not established enough or not small and low wattage enough.
    > those paragraphs would seem to indicate that I spoke broadly
    To me they indicate being focused on the MPC5121e and systems based on that very SoC.
    > I don't think you linked it right.
    I think I did.
    > Why don't you just quote it completely here?
    Done.
    > Let the readers decide from that.
    Of course. It's all about transparency.
    > All without fresh commentary from you or me.
    Huh? Of course I do comment these paragraphs to prove that you subsequently try to mispresent their contents. After all, commenting them is what you just did yourself.
    > I'll leave it alone after that unless you start at it again.
    Starting exactly *what* again? Answering your postings that are directed at me?
    > I'm not going to respond to the stuff you said in the couple of posts before this
    Yes, that's quite obvious.
    > For the record I disagree with it.
    For your record I see that you ran out of arguments :-)
  • »31.07.10 - 19:32
    Velcro_SP
    [ Edited by Velcro_SP 20.04.2011 - 06:54 ]
  • »31.07.10 - 20:34
    Velcro_SP
    [ Edited by Velcro_SP 20.04.2011 - 06:53 ]
  • »31.07.10 - 20:50
    > I asked Andreas to give you the straight quotes so you could read them
    Which I did.
    > without him (or me!) telling you what they mean.
    You *did* tell what you subsequently are trying to present as their meaning. I quote your own words from your posting I just responded to:
    "both of those surrounding paragraphs refer specifically not only to 5121e-based platforms but to non-5121e-based platforms: above to Limebooks (which includes X86 models, remember?) and below to ACube PPC computers."
    So when you yourself do that why should I not be allowed to do the same? Double standard?
    > instead he wrote you
    Wrong, to *you*, Velcro_SP. It's really just you I'm talking to when responding to your postings.
    > a short story to explain them
    I just proved that you mispresent what you actually wrote in those paragraphs. By commenting them I don't keep anyone from reading them like I quoted them in full (as you wished) and making up their own mind. I think you're underestimating the discernment of others by far.
    And why should I quote what you wrote without commenting it when I even linked to it just before? If that doesn't satisfy you then it's up to *you* to quote your own words without commenting them in any way.
    > to you.
    > I disagree with everything he said.
    I didn't expect anything else.
    > The part where he says I "subsequently tried to misrepresent" is untrue.
    I think the part where I say this is nothing but the truth. And I think I proved it.
  • »31.07.10 - 21:44
    It's you who are incorrect.
    Fine, we have established that you believe that you believe your words to state something contrary to what they would appear to state.
    Really, that's childish isn't it? Listen, despite what you've said to me, which has been fairly bad, and I don't retract what I said to you in response, I do give you enough credit that I wince to see you acting like that, and it makes me sorry for my part in the whole affair, which I don't enjoy at all.
    Well, again we can agree on one fact. That is has deteriorated into something childish. I don't ask that you retract anything you've said about me. At my age if you're not comfortably assure of yourself, then you're probably neurotic.
    But don't you think resuming this argument after such a long time is rather childish in itself? And if you won't retract what I perceive as a misstatement (and you stand by it) then who benefits by this continued, repetitious argument?
    Frankly, at first my only interest in this was to dissuade you and Andreas from continuing to repeat what had been a thoroughly rehashed difference of opinion.
    But now I must admit that we all must be enjoying this on some level.
    I certainly wouldn't continue to respond if this was actually about an e300 cored processor.
    Its more of a character test, and I think you and I are both losing (since we've both failed to stick to the facts).
    But, is it bad form to interrupt a thread that degenerated into two individuals trading back did too, did not comments? And is it unreasonable to poke fun at the entire matter? No, I don't think either is the case.
    [Quote]
    It's not typical of me.
    [Quote]
    No? Check my postings. I've readily admitted when I've been wrong in the past.
    You say you do the same, but where's the evidence of that?
  • »31.07.10 - 23:42
    Velcro_SP
    [ Edited by Velcro_SP 20.04.2011 - 06:48 ]
  • »01.08.10 - 11:48
    Golem
    Posts: 766 from 2003/2/28
    Ok, so someone needs to work on their issues, not sure this is the place for that.
  • »01.08.10 - 12:15
    Velcro_SP
    [ Edited by Velcro_SP 20.04.2011 - 06:51 ]
  • »01.08.10 - 14:38
    feanor
    Posts: 104 from 2009/3/20
    STOP, PLEASE! BOTH OF YOU!
  • »01.08.10 - 15:31
    > I responded briefly to your observation that the neighboring paragraphs
    > "specifically" referenced 5121-based systems and its clear implication that
    > therefore the middle one does too.
    Yes, and by doing so you commented these paragraphs. That's why I don't understand that you asked me to not comment them either when in fact you did.
    > I said that they also specifically reference other systems and so that
    > logic really seems to lean the other way.
    You are right. The 3rd paragraph mentions ACube systems specifically. Here I said something I didn't mean. Sorry for that. I was thinking of "mainly" when I wrote "specifically". My bad.
    > I then said just post the paragraphs since you brought it up, don't further comment
    Yes, you said that in the same posting where you yourself had commented them.
    > and let others decide.
    I don't think it's about any "others". At least not from my side. But of course it's a public discussion and anybody can take part in it, passively or even actively.
    > You didn't say "main point" at the time. That's different from your "specifically."
    Yes, you're right in that. See above.
    > "Main point" requires reading and evaluation.
    Yes, that would be my "short story".
    > Before I do that, would you mind clarifying what your end point is? That I specifically
    > advocated putting a PowerVR chip on a 5121e-based system and wasn't speaking
    > of anything else at all?
    No, but that you were also (and, by taking the two surrounding paragraphs into account, even mainly) speaking of MPC5121e based systems and thus also (or even mainly, see above) advocated putting a PowerVR chip on an MPC5121e based system.
    > That you recognized I was speaking broadly but putting a PowerVR chip on
    > a 5121e-based system was one possible outcome?
    No.
    > That maybe I wasn't advocating that at all, but you had fair reason at the time to
    > believe it and did believe it because of the context and the words I used?
    Short answer: No.
    Long answer: The second part (after "but") would be "yes". The first part fails to regard the conceptual difference between "intending (not) to advocate" (which only happens in the author's mind) and "actually (not) advocate" (which is what is actually written down). As I can't read your mind (and also couldn't at that point in time of course) I cannot answer that question as a whole with "yes" because I'm confident that your actual *words* advocated (also, or even mainly) putting a PowerVR chip on a 5121e based system, which I objected to.
  • »01.08.10 - 15:35
    "I know you think you understand what you thought I said, but I am not sure you realize what you heard is not what I meant." Richard Nixon
    "Mistakes are always forgivable, if one has the courage to admit them." Bruce Lee
    [ Edited by Jim on 2010/8/10 20:58 ]
  • »01.08.10 - 19:13
    Velcro_SP
    [ Edited by Velcro_SP 19.04.2011 - 15:15 ]
  • »02.08.10 - 22:51
    jcmarcos
    Posts: 1178 from 2003/3/13
    Velcro_SP wrote:
    feanor, you know how to interrupt.
    Making friends, I suppose.
  • »03.08.10 - 07:40
    feanor
    Not really, I am usually able to communicate with my friends and a "please stop" works. Here, I failed to make it apparent that the argument was totally boring and pointless. I'm sorry I "yelled".
  • »04.08.10 - 15:54
