New SAM460EX
    Posts: 12080 from 2003/5/22
    > I spoke to the principle, not to these distinctions
    It's not my fault if you use terms that actually do not represent your thoughts. I can't read your mind. So if you write about a "chip" then I assume you actually mean a chip. Make sure you say what you mean, else communication just cannot work. And if you don't know the proper terms then read up on them beforehand (Internet makes that part easy). It's really not that hard to grasp the concept of what a computer chip is, I think.
    If you mean the "principle", as you say, then use the term "hardware". That's rather generic. A chip is a special kind of hardware, as is a core, which usually is part of a chip.
    > The principle is wider
    Your text mentioned a chip. That's what I referred to. It may be that you *thought* of the wider principle, i.e. hardware in general, but I can not read your thoughts.
    > I spoke generally and informally.
    I didn't know that the term "chip" does generally and informally describe the wider concept of hardware. I thought it's more the other way round (i.e. you can generally say "hardware" and refer to for instance a chip or a core, but you can't say "chip" and refer to other hardware than a chip).
    > I don't "try to turn into" anything.
    After I questioned your "chip" use you claimed you "spoke to the general idea of making use of (note: not necessarily "adding," esp. where already present) dedicated video hardware". But that's actually not what you *spoke* (= wrote) of, but rather what you may have *thought* of. That's a difference.
    > Actually video is a narrower concept than graphics, so those
    > words are as much narrower as wider.
    Huh? I was never about "video" vs. "graphics" but about "hardware" vs. "chip". You can use for instance "video card" and "graphics card" synonymously (at least that's my understanding from reading native English speakers here and elsewhere) but you cannot use the term "graphics chip" and actually include it to mean a graphics core which is inside a SoC (which itself *is* the chip actually). (But you can use "graphics hardware" and mean for instance a graphics card, a graphics chip or a graphics core.)
    > you really thought I meant that adding a second PowerVR to the
    > 5121e board would boost its performance. Yes or no?
    I didn't know what you *meant*. I just read what you *wrote*. And I tend to assume that one writes what he means. So the answer to your question is: Yes, I assumed that by "chip" you really meant a chip.
  • »28.07.10 - 00:55
    Velcro_SP
    Posts: 929 from 2003/7/13
    [ Edited by Velcro_SP 20.04.2011 - 06:58 ]
    Pegasos2 G3, 512 megs RAM
  • »28.07.10 - 01:35
    > I think the problem is with your perception not my expressing myself.
    I think it's the opposite.
    > Strangely enough, no-one else but you seemed to acquire from those
    > clearly general words that I advocated putting a second PowerVR on a 5121e.
    Huh? I didn't acquire that you "advocated putting a second PowerVR on a 5121e" (how should that even be done?) but that you advocated putting a second PowerVR on a board with an MPC5121e, i.e. in addition to the MPC5121e. Seems you never stop confusing boards and chips *sigh*
    > you say yes, you really thought that was what I meant, eh?
    Yes.
    > Can we get a straight answer from you, Mr. Precision?
    Of course. I'm known for giving straight answers all the time. As well as I like to get straight answers to my questions.
    > That's honestly what you thought I meant?
    Again: yes.
  • »28.07.10 - 02:19
    Velcro_SP
    [ Edited by Velcro_SP 20.04.2011 - 07:09 ]
  • »28.07.10 - 04:21
    jcmarcos
    Posts: 1178 from 2003/3/13
    And now you realize that your fight was about a misunderstanding? You can't do that to all of us, we're all serios here!
    Take both a rest, pick bigger and not discharged weapons, and then come back for the fight!
  • »28.07.10 - 08:00
    Henes
    Posts: 507 from 2003/6/14
    Even this should be avoided if possible.
    Video card and graphics card used to reference two very different types of hardware, specially in an amiga context where video was an important point. Too bad I can't remember the name of any video card which existed in the past :)
    Nowaday, video card's hardware is probably nearly always part of a graphic card though...
  • »28.07.10 - 10:04
  • JJ
    JJ
    Posts: 147 from 2010/7/7
    Maybe just call them GPUs or GPU Cards 8-)
    We don't stop playing because we grow old; we grow old because we stop playing. - George Bernard Shaw
    Xbox Live: S0ulA55a551n2
  • »28.07.10 - 14:12
    No, video/graphics cards are basically the same thing. And if Andreas seemed relentless about this "misunderstanding" its because it was based on a misstatement (or at least a poorly worded statement) that Velcro wouldn't acknowledge.
    Then again, this thread has gotten really stretched out over a single beleaguered point.
  • »28.07.10 - 16:20
    > I guess you honestly thought I meant that too.
    Yes. That's why you wrote it, isn't it?
  • »28.07.10 - 18:46
    Velcro_SP
    [ Edited by Velcro_SP 20.04.2011 - 06:59 ]
  • »28.07.10 - 22:43
    Golem
    Posts: 766 from 2003/2/28
    Can we let this inane nonsense go now?
    Thanks
  • »28.07.10 - 23:01
    Probably not, but you could lock the thread. That would be the first time I've seen that occur on these forums.
  • »28.07.10 - 23:22
    Velcro_SP
    [ Edited by Velcro_SP 20.04.2011 - 06:56 ]
  • »28.07.10 - 23:30
    > I will use the term 5121e to refer to the board
    Seems like you're trying to invent your own fantasy terminology then. That way proper communication is moribund. What term will you use to refer to the chip? And how will you express yourself when talking about the chip and the board in one sentence or paragraph?
    > I don't necessarily type out the full nomenclature
    The difference between a chip and a board has little to do with nomenclature. It's a fundamental *technical* difference.
    > As far as I'm aware, you're the only one who
    > seems to struggle with comprehending this.
    "Seems" is the keyword here. While I can't speak for others I know that not objecting to something doesn't equal understanding it.
  • »29.07.10 - 00:32
    > on these forums.
    When Genesi and some MorphOS Team members had a public go at each other in a thread some years ago (December 2004 IIRC) server problems suddenly appeared that resulted in deletion of a bunch of threads with said thread among them. Probably just bad timing ;-)
  • »29.07.10 - 00:36
    > they don't even say "adding"
    Huh? How should there possibly be a "dedicated graphics chip" if not by adding it?
    > or "5121e" in there.
    That's why I asked you several times already: And now you say that inbetween, i.e. in the 3rd paragraph, you didn't mean to include the MPC5121e when mentioning "slow, low-wattage processor"? Yes or no?
    As far as I'm aware you haven't answered that question yet.
  • »29.07.10 - 01:05
    @ Velcro
    No, I've owned multiple TV tuner cards, but I've never thought of them as video cards. And, since I've been building computers since before we had dedicated video cards (and you had to use terminals) I don't know anyone else that would make that mistake.
    You might as well argue that a video input card is as a video card, but its not.
    And, while I threw out that one statement with a sense of amusement over how drawn out this has been, you could have concluded this childish back and forth bickering long ago.
    Your statement was a clearly wrong as Andreas pointed out. If it was a misstatement and you meant something else, why not just say so?
    Exceptionally hard headed attitudes have keep us focused on a minor point about hardware most of us gave up on a while ago.
    [ Edited by Jim on 2010/7/29 2:17 ]
  • »29.07.10 - 01:16
    Velcro_SP
    [ Edited by Velcro_SP 20.04.2011 - 07:57 ]
  • »29.07.10 - 02:08
    Velcro_SP
    [ Edited by Velcro_SP 20.04.2011 - 07:52 ]
  • »29.07.10 - 02:17
    > A board where the chip is already there perhaps.
    And how did it go into the board design if not by adding it?
    > any slow wattage processor is included and any specialized graphics hardware
    ...which you called "chip".
    > Yes, of course this includes the 5121e
    Fine. That's what I assumed.
    > it doesn't equal the advocacy of the absurd result of double PowerVRs, which
    > is what you were saying.
    If you have a PowerVR core inside the MPC5121e on a board and have a "dedicated graphics chip" in the form of a PowerVR on that same board then this makes two PowerVR cores on that board in total. Simple maths.
  • »29.07.10 - 02:19
    > I still can't get data out of Applied Micro on the APM 83290 SoC
    Over there on the Bunny minator claims:
    "AMCC cancelled Titan"
    http://moobunny.dreamhosters.com/cgi/mbmessage.pl/amiga/174889.shtml
    Do you think that could be true? I'm not sure if to trust someone who says that the e500 is a G3 though ;-)
  • »29.07.10 - 03:06
    No Applied Micro's not about to give up on Titan. Its the only really powerful core they've got (compared to other company's high end offerings).
    BTW - I'm not butting into this one again because the entire group of postings is painfully stupid. I would have taken the use of the term 'chip' to mean an additional discrete component too.
    Besides if Velcro think you need me to help you, he doesn't know you very well.
    I don't have to state who's right and who's wrong and the only thing that's asinine about the whole situation is how often you've had to restate the basic point that the comment was poorly worded and misleading (if he meant something else).
  • »29.07.10 - 03:28
    Henes
    That's an incorrect generalization. Don't know about what henes said, but many people say "video card" to refer to a TV card.
    See there for so called video cards (plus some others like the Peggy):
    http://www.amiga-hardware.com/showcat.cgi?CATID=17
    Specially the OpalVision and the AVideo24 are good exemples.
    [ Edited by Henes on 2010/7/29 15:05 ]
  • »29.07.10 - 13:04
    OK, I'm open to the idea of sticking with the term graphics cards rather than just a generic term like video card (at least while dealing with Amigans).
    The last thing I want is another drawn out argument over a minor point.
    Is graphics card acceptable, or is the fact that that listing mentions "Graphics and Video cards" going to be a sticking point?
  • »29.07.10 - 16:07
    Velcro_SP
    [ Edited by Velcro_SP 20.04.2011 - 07:48 ]
  • »30.07.10 - 01:10
