Very Slow Network Transfer - Hours - X5000
    Posts: 900 from 2003/3/4
    amigasociety wrote:
    The NAS is directly connected to the same.
    I will get model info later today as well as do a test of unplugging the exact cable from my X5K and plug into my 2019 Mac Pro and do a transfer to make sure no cable issue.
    I will transfer the same file in question as well.
    It was smart to do this, as it does sound awfully like a cable issue.
  • »10.03.25 - 22:48
    I also seem to remember that jumbo frames in some NAS don't play nice with some NICs. Anything in NAS settings to turn off?
  • »10.03.25 - 22:50
    Posts: 3306 from 2003/3/5
    @amigasociety
    Just wondering: if you open Network settings and go to Advanced tab, are the Socket Buffer sliders both at 65536 bytes? If not, does setting them to the max value help?
  • »11.03.25 - 10:53
    Posts: 108 from 2023/12/1
    Just tried, unfortunately no.
    Same slow to not happening speed.
    I went into System and Advanced as noted and slide the two socket bars, one for send and one for receive, to the max which was 65536 and saved.
    Tried a copy and no luck.
    Even rebooted and tried a 2nd time but same issue.
    TJ
    *then I typed in the tcpdump in shell and all transfered OK so yeh, whatever it is I am typing in this shell makes the transfers work much faster.
    jacadcaps wrote:
    @amigasociety
    [ Edited by amigasociety 11.03.2025 - 05:34 ]
  • »11.03.25 - 12:30
    Interesting. I'll try to see what tcpdump enables/changes in the networking stack settings, but as I don't have your hardware to test, I might not be able to help.
  • »11.03.25 - 14:08
    Appreciate the help.
    I am always willing to try things as you can see so if you think something may help, just let me know.
    Thanks for the help.
    TJ
  • »11.03.25 - 14:42
    Out of curiosity, are there any Devs or others users here with X5K and running MorphOS?
    TJ
  • »11.03.25 - 14:58
    I will throw this out as well, in case there are no DEVs with an X5K, that I am happy to try stuff the MorphOS team wants to throw at me. I am no super tech but I am persistent, so I tend to work on an issue until I can get a meaningful solution, and do have a tech background as well, just not a SUPER tech. haha.
    I use tons of vintage to modern computers and do throw my own ideas at things as well, good at reporting what I may find or see, etc...
    Therefore if a user with an AmigaOne X5K can be of benefit to all, let me know how I can help.
    Mine is a dual boot X5K, with a THANK YOU to Skateman for helping me get the dual boot working.
    In the past I had dual booted AmigaOS and Linux on my past AmigaOne X1K as well as my Tabor 1222 when I used to own one, but never the X5K so his help is most appreciated and why I have a dual boot X5K today, and I may add linux to it for Triple Boot one day.
    For now I just wanted a dialed in AmigaOS and MorphOS so I can decide if getting a MorphOS license for good on this X5K is in order. I used to have a MorphOS license for a G4 Mac Mini but sold that long ago.
    TJ
    [ Edited by amigasociety 11.03.2025 - 09:31 ]
  • »11.03.25 - 16:28
    Just a quick note, for the sake of doing it, I updated to MorphOS 3.19 but no difference in the issue above.
    TJ
  • »13.03.25 - 14:27
