Posts: 2207 from 2003/2/24
Papiosaur wrote:
In Shell, seems CTRL + C, CTRL + X, CTRL + V don't work, only via contextual menu.
The normal rcommand+c/x/v works in the Shell, just like on Amiga, MorphOS, and Mac everywhere usually. For some reason someone has decided to configure inconsistent Windows-alike shortcuts (ctrl) to Ambient, which causes confusion.
Actually rcommand+c/x/v works in Ambient too, despite what you have configured in the Ambient Hotkeys settings, but there seems to be a small illogigal issue with it.. it doesn't paste to the current directory, but to a selected directory...
In MUI settings you can have two shortcuts for the same operation, so both cmd+c/x/v and ctrl+c/x/v are supported there. Maybe Ambient and Shell settings should support two shortcuts too, to get it work in both ways.
If possible to add them, it will be usefull i think.
You can configure them in the Shell (MUIConsole) prefs yourself, if you want to change it from command to control.
