YT 2.4 crashes since 5.4.2024
    Posts: 1363 from 2010/1/6
    Seems that some URLs of Youtube let URL-Extractor going crazy (https://m.youtube.com/watch?v=z-bKfdtXGn8&pp=ygUjcMOkc3NlIHB1ZmZlciBwYWxhdHNjaGlua2VuIGZvbGdlIDI%3D):
  • »09.04.24 - 19:42
    igracki
    Posts: 463 from 2003/2/24
    Hmm, its because the stream-infos contains double quotes, this corrupted the body/gadgets of the Requester.
    I uploaded a halve-fix for this, I now remove double quotes from the stream-infos, so the Requesters body now shows the stream-infos.
    I think this is a bug in the original script.
    Can someone check if this works for the OS4 version?
  • »15.04.24 - 14:53
    Cego
    Posts: 738 from 2006/5/27
    @igracki
    i have tested the yt script on OS4 and it seems that with certain videos the extraction is also broken.
    "Amiga Story" (working)
    https://ibb.co/02988qH
    "Das Rätsel der Riesenlaufvögel" (broken)
    https://ibb.co/rb3MRWw
    https://ibb.co/x17rZFN
    [ Edited by Cego 16.04.2024 - 22:40 ]
  • »16.04.24 - 19:35
    Cego
    Is it possible to select between mplayer and ffplay as player? There is a line in yt.cfg for ffplay path, but i havent figured out how to use it. I'd like to watch regular YT videos with MPlayer and live streams with ffplay (as MPlayer doesnt support live streams)
  • »17.04.24 - 08:21
    Thank you Andreas (and Igraki!!) - did'nt see the new version! Works now flawless again.
    [ Editiert durch Amigaharry2 29.07.2024 - 23:25 ]
  • »29.07.24 - 19:24
  • ghh
    ghh
    Posts: 60 from 2017/7/15
    Michael Trebilcock released a new version of his super YT 2.8.
    Here is my MorphOS modification http://ghh.8u.cz/friends/YT_2.8mod.lha
    There is a "ytplay" program in the archive that will run another modified ytplay.rexx script with the video address in the clipboard.
    In the yt.conf file, edit only the path to mplayer.
  • »08.08.24 - 22:08
    igracki
    Here is the new v2.9 of Youtube URL Extractor.
    This seems to need curl v7.53.1 (included).
    Before I used curl v7.43.0 this doesn't work, also curl v8.2.1 from SDK doesn't work.
    Maybe some can port curl 8.10.0?
  • »16.08.24 - 16:03
    igracki
    I uploaded the wrong archive, sorry! It's v2.7.
    I'll upload the correct archive later in the evening.
  • »17.08.24 - 06:20
    igracki
    Ok, now the correct v2.9 can be downloadedhere.
    When I said that you need the curl v7.53.1 I only tested it with this specific url
    https://www.youtube.com/watch?v=KLNSpZILqso.
  • »17.08.24 - 14:33
    igracki
    Michael Trebilcock just released v3.0 of his brilliant yt.rexx script!
    Here is my MorphOS version.
    Here is his changelog:
    3.0 - 18th Aug 2024:
    - Fixed a crash relating to ampersands and percentages.
    - Updated list of tags and labels.
    - Support links from YouTube shorts.
  • »19.08.24 - 13:51
    Oh - Wow! Thank you!
  • »19.08.24 - 15:45
    Cego
    @igracki
    yt-search script doesnt work anymore. Search results will be shown, but it wont load the video
    "unable to find video information"
    [ Edited by Cego 17.11.2024 - 10:57 ]
  • »17.11.24 - 09:56
    igracki
    This seems to be a general with the yt script / youtube.
    We have to wait for Michael for a new version;)
  • »17.11.24 - 15:03
    igracki
    Michael Trebilcock also noticed the issues with his script and proposed using ANDROID option.
    Just tried it and yes using ANDROID works!
    When using the yt-search script you have to edit the yt-search_action script and add the ANDROID option in the almost last line where the yt.rexx script is called:
    Run >NIL: rx >CON:100/200/600/300/yt-Search/Close rexx:yt.rexx "{VidURL}" WAIT ANDROID $what
    If you are using SmartClipboard.sbar to automatically run the script if you copy a youtube url to the clipboard you have to go the Action-Editor of SmartClipboard.sbar and add the option ANDROID in the command column.
    [ Edited by igracki 18.11.2024 - 13:50 ]
  • »18.11.24 - 11:47
    Cego
    yt-search via shell works now! But how do i get it to work with OWB and Invidious Search engine? When i right klick the yt link in OWB and select "Play Video...", i get the "unable to find video information" again.
    I just had to add "ANDROID" to the context menu entry in the OWB prefs
    [ Edited by Cego 18.11.2024 - 20:58 ]
  • »18.11.24 - 19:57
    Where did you insert "ANDROID" exactly? Because method of igraki above does'nt work here....
  • »18.11.24 - 20:11
    Cego
    OWB Contextmenu
    [ Edited by Cego 18.11.2024 - 21:18 ]
  • »18.11.24 - 20:17
    Ok, Thank you - works!
  • »19.11.24 - 09:27
    Now serch-funktion in AIOSTREAMS is dead..................hope this can be fixed......
  • »25.12.24 - 19:32
