YT 2.4 crashes since 5.4.2024
    Posts: 1332 from 2010/1/6
    YouTube has changed something again. YT_2.4 Url Extractor crashes now since 5.4.2024 the whole system
    Does anyone know how to contact coder of YT_2.4, Michael Trebilcock? There are no infos in archive....
  • »07.04.24 - 05:38
    NewSense
    Posts: 1535 from 2012/11/9
    Michael Trebilcock created this originally for OS4 - his archive is here - YouTube_URL_Extractor - currently for OS4 at v2.5, last updated December 2023 and it was converted from a prior release by Thomas Igracki for MorphOS from Michael's efforts as version 2.2, which seems to be the current one available from MorphOS-Storage.
    Where you have v2.4 from for this utility I do not know?
    So, we seem to be a few updates behind the OS4 version currently. Michael Trebilcock, who seems to be a busy guy for OS4, as he has quite a few programs assigned to his profile. If you contact OS4 depot they should have contact details for him - they are just not in the archive or the readme, likely so he does not get pestered by 'bots', etc..
    Not sure if Thomas Igracki is still in contact with Michael Trebilcock, but if we are talking about a more up-to-date version based on Michael's current version then Thomas is probably the best person on M-Zone to PM or email to ask about any update/fix being possible for MorphOS. ;-)
  • »07.04.24 - 07:17
    igracki
    Posts: 461 from 2003/2/24
    I updated the yt script to v2.5 in january, but upload to MorphOS storage failed back then, and I forget to reupload... sorry;)
    you can download it here
  • »07.04.24 - 10:56
    Cego
    Posts: 738 from 2006/5/27
    Thanks igracki! Sadly the new version also crashes. Any ideas?
    [ Edited by Cego 07.04.2024 - 14:15 ]
  • »07.04.24 - 11:15
  • ghh
    ghh
    Posts: 60 from 2017/7/15
    And here is my 2.4 modification:)
  • »07.04.24 - 11:22
  • ghh
    ghh
    Cego: Try PathSMonk="c:js_spidermonkey" in YT.cfg
  • »07.04.24 - 11:32
    igracki
    Please try with an updated duk/js (v2.7, the previous was v2.2),
    here
    Copy "js" c:
  • »07.04.24 - 12:04
    Cego
    Thanks! Spidermonkey did the trick. But playback in MPlayer takes a long time to start and it's very laggy. AmiTube works nicely though with MPlayer.
    [ Edited by Cego 07.04.2024 - 16:20 ]
  • »07.04.24 - 13:19
    igracki
    Can you post the YouTube URL Cego?
  • »07.04.24 - 14:58
    Cego
    yes of course :)
    Amiga Documentary Link YT
  • »07.04.24 - 15:19
    Does'nt work for me anyway! Allways stops as shown in pic. When trying to brake (ctrl c) -> Crash!
  • »07.04.24 - 16:54
  • ghh
    ghh
    Yt 2.4 works for me, I have js 1.5 (filesize 876756) in my "YT/tools/" directory.
  • »07.04.24 - 17:46
    Cego
    @igracki
    i also wanted to ask if its possible to improve yt-search script, so it'll show the result with their respective Youtube title? The way it is now, i can only see Video URLs. This makes it impossible to select the desired video
  • »07.04.24 - 18:03
    Where can I find this version V1.5? All I found in all links above is js with size 439732 resp. V1.4.
  • »07.04.24 - 20:00
  • ghh
    ghh
    @Amigaharry2
    Js 1.5 is here or in archive from igracki #4
    (yt/sys/c/js_spidermonkey)
  • »07.04.24 - 21:02
    Works now, but all addidional programs, like js, etc. must be located in YT:Tools. If located in C: it won't work.
    As Cego wrote: playback (Mplayer) is very laggy and higher resolutions than 320p are not possible now: takes endless time to start and runs as Slideshow! In past 720p where no problem on G5....
  • »08.04.24 - 08:10
  • ASiegel
    Posts: 1387 from 2003/2/15
    Sounds like the wrong video format is being fetched. (AV1 or h265 vs. h264)
  • »08.04.24 - 11:07
    igracki
    Cego wrote:
    yes of course :)
    Here yt v2.5 with new js (duktape) v2.7.0, works with this video!
  • »08.04.24 - 11:30
    Papiosaur
    Posts: 2409 from 2003/4/10
    Bizarre, the archives don't have all the same files and the same structure... (Tools/, c/...)
    Best way will be to have all in one drawer and the script configured for that.
    It will possible to do one archive correctly configured and updated please?
  • »08.04.24 - 12:51
    igracki
    My yt_v25.lha archive now contains the updated js (duktape) v2.7.0.
    The archive from ghh is v2.4 of os4 yt script, with same file structure like the original os4 version of yt.
  • »08.04.24 - 14:26
    Cego
    Great! Playback is smooth now!
    Any chance we could get an updated yt_search script with YT Titles? :)
    Thank you!
  • »08.04.24 - 14:51
    Installed this archive and - nothing happens! Now even shell-window of Url-extractor doesn't open (flashes up only short).
    What are this 2 js-files (...duk_V2.2.0 and ...duk_2.7.0)?
    Edit: I found the problem: the old config-file! Works now!
    A great "thank you" to igraki and ghh!!
    [ Editiert durch Amigaharry2 08.04.2024 - 21:03 ]
  • »08.04.24 - 16:55
    Aha, thank you Andreas!
    @igraki: I've seen that buffered files are not deleted, if video is'nt played till the end.
  • »08.04.24 - 18:49
