SDL2 sources, progress and ports
    Posts: 562 from 2004/4/15
    I am missing the SDL_ttf.h in the SDK.
    Did I miss something?
  • »23.02.21 - 20:41
    beworld
    Posts: 577 from 2010/2/10
    Oh.... sorry
    I fix that and upload new archive
    Missing SDL_mixer.h, SDL_net.h, SDL2_ttf.h, SDL2_image.h and SDL2 gfx... mm
    IMac G5 2.1,PowerBook G4 1.5,MacMini 1.5, PowerMac G5 2.7 died !!!
    My MOS ports
  • »23.02.21 - 21:49
    Perfect, thx!
  • »23.02.21 - 21:56
    IngaSdl2 Engine is working well with your sdl2 port:
    What is worth to mention from my side:
    1. SDL_CreateRenderer with SDL_RENDERER_ACCELERATED or SDL_RENDERER_PRESENTVSYNC did not work. I needed to use SDL_RENDERER_SOFTWARE.
    2. SDL_GetBasePath did not add the path separator at the end
    see documentation:
    * This returns an absolute path in UTF-8 encoding, and is guaranteed to
    * end with a path separator ('\\' on Windows, '/' most other places).
    Thx again beworld for the SDL2 port!
    [ Edited by eliot 25.02.2021 - 08:28 ]
  • »25.02.21 - 09:27
    beworld
    You can use 0, SDL2 chooses the first RENDERER available
    I take note of your remarks, thank you
    My MOS ports
  • »25.02.21 - 14:16
    @beworld:
    just one more remark:
    SDL_SetCursor and SDL_ShowCursor do not have any effect on morphos currently.
    On Linux and Max the cursor changes when running Ermentrud, but on mos the mouse cursor does not change.
  • »26.02.21 - 11:26
    beworld
    @eliot
    What do you send to SDL_CreateCursor ?
    do you have any sample code that i can reproduce the problem?
    Thanks
    My MOS ports
  • »26.02.21 - 11:49
    Inga is using a surface, see:
    https://github.com/eliot-exdev/inga-sdl-1/blob/master/sources/Cursor.c
    But maybe there is something else wrong, I will have a look into it.
    On other systems it's working, but this means nothing.
  • »26.02.21 - 11:56
    beworld
    ok i check if i see something...
    [ Edité par beworld 26.02.2021 - 17:46 ]
    My MOS ports
  • »26.02.21 - 15:23
    tolkien
    Posts: 487 from 2013/5/29
    eliot escribió:
    @beworld:
    I think I had the same problem when trying to port protracker clone.
  • »26.02.21 - 18:29
    beworld
    I dont have this problem with OpenTTD and ScummVM here.
    Maybe .bmp is wrong format, i dont know for now....
    My MOS ports
  • »26.02.21 - 18:56
    beworld
    My MOS ports
  • »26.02.21 - 18:56
    Hm, strange.
    Which format are you using in Scumm and Openttd?
  • »26.02.21 - 19:41
    beworld
    After some time, i think you right, we have a bug with no-system cursor.....
    I try to see with BSzili if we can fix that.
    In ScummVM or OpenTTD, they dont use directly SDL_CreateCursor...
    My MOS ports
  • »26.02.21 - 21:30
    From which branch you are currently bulding the
    libs and the sdk? Maybe I can have a look
    into that.
  • »26.02.21 - 22:30
    beworld
    all code is here :
    https://github.com/BSzili/SDL/tree/mos-sdl2/src/video/amiga
    When you call SDL_CretaCursor, all seem pass here :
    https://github.com/BSzili/SDL/blob/mos-sdl2/src/video/amiga/SDL_amigamouse.c#L55
    I try to look in SDK, we have an example in Intuition "argbpointer.c"
    Thanks
    My MOS ports
  • »27.02.21 - 06:37
    yes the call seems to be ok, but nothing happens (mouse pointer does not change).
    I will also have a look into the code.
  • »27.02.21 - 07:30
    beworld
    Yeah !!! i think i find :
    https://github.com/BSzili/SDL/blob/mos-sdl2/src/video/amiga/SDL_amigamouse.c#L61
    In SDK example, it's not same, i try to use Object and it's working now :-)
    Need more test, and i update repository
    My MOS ports
  • »27.02.21 - 07:44
    Yeah, sounds great!
  • »27.02.21 - 09:40
    beworld
    Ok you can find on storage new archive with fix.
    Thanks again
    My MOS ports
  • »28.02.21 - 07:33
    Thx beworld,you are the man! It's working fine now with Ermentrud/Inga.
  • »28.02.21 - 10:09
    beworld
    New Package with SDL 2.0.14 version is available.
    News:
    - somes fixes for SDL2
    - add OPENGL RENDERER in state (with transparency buggy.. but not affect all exist ports)
    - lot of update of dependencies of SDL2_mixer, SDL2_image, SDL_ttf
    more on readme/changelogs
    Available on MorphOS-Storage.net
    My MOS ports
  • »20.04.21 - 11:11
    Hi all,
    I just had a try to use new OpenGl feature together with Inga engine (Ermentrud).
    Sadly Timo is using one big texture where everything is rendered into:
    prerenderTexture = SDL_CreateTexture(renderer, SDL_PIXELFORMAT_RGBA8888, SDL_TEXTUREACCESS_TARGET, SCREEN_WIDTH, SCREEN_HEIGHT);
    SDL_SetRenderTarget(renderer, prerenderTexture);
    this seems currently not supported by SDL/OpenGl:
    SDL_CreateTexture: Render targets not supported by OpenGL
    Is there any chance to get this feature working on MorphOs port?
    It would really be nice to have the OpenGl renderer, because it's much faster than sw renderer.
  • »26.08.21 - 19:22
    beworld
    Tinygl has no FBOs, so there's nothing that can be done on the SDL side.
    BeWorld
    My MOS ports
  • »27.08.21 - 08:54
