AmiWest 2017 Demo
    Posts: 12077 from 2003/5/22
    > Lack of 3D acceleration is a deal killer for me [...]. [...]
    > the HD 6870 [...] has very good OS4 [...] support
    OS4 completely lacks 3D support for it.
  • »25.10.17 - 22:20
    > If the GCN cards vended with the X5000 perform significantly better under OS4
    > than say a high end Northern Islands , I'd be somewhat surprised.
    At least in terms of 3D acceleration the GCN cards perform infinitely better ;-)
    > support for Northern Islands under OS4 is pretty good
    See my previous comment.
  • »25.10.17 - 22:38
    Debaser
    Posts: 161 from 2005/7/12
    Acill and all involved:
    Thanks for supporting Morphos at Amiwest this year. Cool to read your feedback and observations as well. I am really looking forward to installing 3.10 on my X5000.
  • »26.10.17 - 15:35
    Spectre660
    Posts: 275 from 2015/6/30
    Brings to mind another question :
    Will a separate hard drive be required or can AmigaOS 4.1 and Morphos 3.10 be installed on the same hard drive ?
  • »26.10.17 - 15:57
    Posts: 1914 from 2003/10/19
    As long as you have SFS you can put it on the same drive partitioned sure.
  • »27.10.17 - 15:12
    How is the filesystem relevant for this and why is it restricted to SFS? Do you mean the MorphOS boot partition, the MorphOS system partition or both?
  • »27.10.17 - 22:22
    Wow, good thing I'm not running OS4, or for that matter an HD 6870.
    I'll probably initially use either an HD 8490 or an HD 6750.
    "2D Driver with compositing" I guess they really don't have better Northern Islands support than that.
    So we'll have 3D from the R200 up to Terascale 3, and then hopefully we'll see similar support for GCN cards.
    While they have a huge gap in their 3D support.
    Curious.
  • »27.10.17 - 22:56
    Spectre660
    Both OSes have/will have gaps at various points.
    The MorphOS gap is currently in newer cards and the AmigaOS 4.1 gap in older cards .
    A-Eon had two different developers working on initial 3D support .
    Support for cards in the Radeon HD5000-6000 series has not borne fruit.
    Support for the Radeon HD 7000 series and beyond is producing a fine crop.
    It has taken 5 years to reach this stage from the start of the attempt for the Radeon HD5000-6000 Series 3D up to Warp 3DNova for radeon SI cards .
    Two different 3D product have been produced. Warp3D SI and Warp3D Nova(SI).
    There is also a wrapper for Warp3D via the more advanced Warp3D Nova in the works by another developer.
    This will atomically be able to take advantage of the full graphics memory of the video card introduced in the version of the RadeonHD 3.x driver and should also result in much better performance for Warp3D software including existing binaries.
    There will be more fun when we have an overlap in 2D and 3D support for the same cards by the the two Oses .
    Curious.
    [ Edited by Spectre660 27.10.2017 - 20:58 ]
  • »28.10.17 - 00:54
    Thanks for the clarification. I missed the fact that the older drivers did not get 3D support.
    But I have been paying attention to Han de Ruiter's work, on both the GCN video card drivers and Warp 3D Nova.
    The OS4 community is very lucky to have Hans.
    There are more gaps than the one you mentioned.
    MorphOS has not updated its OpenGL support in some time, and does not support more than one Radeon video card.
    2D and 3D comparisons between the two OS?
    Considering the differences between MorphOS and OS4, that could be complicated.
    Particularly since it seems you are aquiring an edge.
    [ Edited by Jim 28.10.2017 - 08:10 ]
  • »28.10.17 - 13:08
    Absolutely.
  • »28.10.17 - 21:13
    Posts: 2720 from 2003/2/24
    I’m not really certain if I understand your point, but a word of caution here: The OS4 forked SFS may use the same name as SFS, but just like ”MUI” their version is not fully compatible. Do not use their FrankenSFS handler on your MorphOS partitions.
  • »30.10.17 - 01:09
    Spectre660
    The SFS file systems are not included with AmigaOS 4.1FE for X5000 .
    FFS and the new NGFS are.
    The SFS filesystems are now part of the A-Eon Enhancer software package so now a separate third party
    installation .
    [ Edited by Spectre660 29.10.2017 - 21:01 ]
  • »30.10.17 - 02:00
    I doubt their would be an issue if the drive was set up a partitioned by MorphOS.
    Even if the partition used by OS4 was altered.
    In any case, I'll be using separate drives on any dual install, so its not really important for me, outside of being able to create partitions both OS' can read.
  • »30.10.17 - 08:33
    The important thing is that you *don’t access* your real SFS MorphOS partitions from OS4 with FrankenSFS handler, and vice versa. To be sure you never mix up, don’t even mount your OS4/FrankenSFS partitions in MorphOS, and don’t mount your MorphOS SFS partitions using FrankenSFS-handler in OS4. Keep’em invisible to each other, and keep’em separated! In other words: do *NOT* try to use SFS and FrankenSFS “to create partitions both OS' can read”.
  • »30.10.17 - 09:33
    Well, now I'll just have to try this, even if it's only to experiment.
    OMG, using SFS handlers from different Amiga related OS', cats and dogs living together, milk free milk. What's next?
    It the end of the world as we know it guys, I'm telling you.
    There can be no mixing! Ever!
    It's unnatural!
    God himself would forbid it, if he hadn't already declared OS4 to be evil.
    Hey, on a calmer note, if I'm not mistaken SFS predates NG, and Ralph Schmidt's work on it. So who is using 'Franken-SFS' is really a matter of perspective.
    If these various implementations don't work with other NG OS' (or Linux for that matter), it seems like that would be the fault of the author of the variant.
    [ Edited by Jim 30.10.2017 - 06:49 ]
  • »30.10.17 - 12:40
    It's unnatural!
    Wow, that's a pretty moronic post, even by your standards.
    By all means, please go right ahead and fuck your file system up all you want, and see if I care.
  • »30.10.17 - 22:55
    It's unnatural!
    Could not care less what you think is moronic. And, since I always have backups, its no big deal.
    Further, I intend to work across multiple OS', so I'll figure something out.
    As this will be a exchange volume, trashing it wouldn't be all that big a deal.
    Not that you would know, since you seem to think this would 'fuck up my file system'.
    Then again, I'm the moron, right (even though I've successfully done this with a countless number of other applications)?
    Dare say, I think you're just pissy because it involves an 'alien' OS.
    Specifically OS4.
    If that sets you off...good. ;-)
  • »31.10.17 - 17:46
    Could you be more specific regarding "this", and whether "this" involved different implementations or forks of SFS?
  • »31.10.17 - 18:28
    Not all all, but SFS exists in multiple OS'. Actually, I've had a bigger challenge with other operating systems where finding a common filing system was much more difficult.
    What grandma seems to think is a monumental task, shouldn't be that challenging, since both MorphOS and OS4 should support SFS as it exists in OS3.X.
    Then again, I'm a moron, so hey, wtf, huh? ;-)
    Again, just the pot calling the kettle black, because the pot is prejudiced.
    No big deal, I face challenges from REAL intellects everyday.
    Frankly, YOU'RE a lot more stimulating Andreas.
  • »31.10.17 - 19:43
    Posts: 873 from 2003/3/4
    The reason TMHG used the unflattering descriptor "FrankenSFS" was because we have no real idea how Joerg Strohmayer diverged from the original - he wasn't exactly vocal or helpful about it. SFS2 was certainly NOT compatible with SFS.
    Mix SFS implementations at your own risk. If you really want to cross-mount them, do so with a mountlist and specify them as read-only.
  • »31.10.17 - 20:46
    Hey, no that is a good (and not at all hostile) idea.
    And don't worry, I don't really concern myself about what people say whether its flattering or otherwise.
    What is comes down to is what I want to get from something, if someone else thinks its too challenging, no big deal.
    And a completely divergent SFS (SFS2) is kind of pointless, isn't it? Why not just give it a new name?
    Anyway, again, no real problems here as I won't even be using my primary volume/drive.
    If it crashes or becomes unreadable, BFD.
  • »31.10.17 - 20:56
    @Jim
    Acill above wasn’t the first by far, it happens from time to time that people who don’t really know the history gets confused about OS4 SFS. Also, people come to these forums to search for info, to learn. Search engines points here. Integrity of file systems are *extremely* important to anyone caring for their data, which most people do! And here you are, actually telling people it’s OK to jump over a cliff because *you* have a parachute or *you* don’t care about safety, fighting the warnings repeatedly with ridiculous “racial” arguments?! That *is* a moronic behavior! Risc your own data all the way you want, but please stop fighting the warnings to clueless people who actually do care!
  • »31.10.17 - 23:29
    @Jim
    'Racial'? More like rabid. And as I've already stated, based on mounting a secondary volume and using it as an exchange medium I don't anticipate loss of anything that can't be restored.
    While I appreciated your advice, I think you underestimate both myself and Acill.
    Neither of us would be likely to experiment blindly with important data.
    And an exchange filesystem needs to be explored for multi-boot systems using MorphOS, OS4 and Linux.
    If not SFS, something else will have to serve.
    I can already save to media that is readable by all OS, and taking this one step further is not an insurmountable issue.
    In the meanwhile, your tone is more than a bit insulting and condescending.
    I think I've managed to learn to approach tasks like this methodically, since I've been using computers for over forty years now.
    @ Andreas, thanks for the initial pointers. It doesn't look completely gloomy. But experimenting with these options will need to be done with caution.
    I'd hate to have to resort to an 'alien' filesystem like the one poster suggested.
    [ Edited by Jim 01.11.2017 - 06:57 ]
  • »01.11.17 - 12:29
    At the risk of being, yet again, berated, what issues would interfere with using FFS?
    And are there any inherent issues with sharing an SFS partition with both MorphOS and Linux?
  • »01.11.17 - 13:03
