AmiWest 2017 Demo
    zbysiuk wrote:
    Just one day you'll look and viola
    Very dyplomatic :)
    ...and I limit my questions
    Thank you very much. You limited your questions but is quite the answer :)
    And yet MOST declared that the x5000 is needed to test new concepts with respect to x64. Do you think they have stepped in the right direction, or have you heard any statements about x64?
    I just like PPC systems, so I'm buying one more (as it doesn't look like I'll get support for my 11,2 PowerMac).
    One last system with a processor that is descended from products produced by Motorola Semiconductor, before a final capitulation to the forces of darkness (Intel). ;-)
    As to X64, that does seem to be what will be the focus after this release (or the inevitable next release that clears up bugs present in 3.10).
    And yes, in a way the current PPC work IS a bridge to X64. The last two systems adopted were our first with PCI-E expansion, and the new video card support is for gpus the utilize a PCI-E interface.
    So a lot of this work provides insight into hardware similar to what we will face when X64 is adopted.
    HEY David!
    You arranged and paid for the display table.
    And while its a shame you couldn't attend, life sometimes throws you curves you need to compensate for.
    Further, you've been presenting demos there for how many year now?
    You deserve all our thanks.
    [ Edited by Jim 23.10.2017 - 13:37 ]
  • »23.10.17 - 18:36
    Posts: 12080 from 2003/5/22
    > the 68K version doesn't seem like much of an option when
    > we have a better native application. ;-)
    Compared to this better native application, even a MorphOS-native IBrowse 2.5 wouldn‘t seem like much of an option for most purposes :-)
    > Does anyone know if there will be a presence at Amiga 32?
    In December 2016, the MorphOS team (cyfm plus other team members) was added as exhibitor.
  • »23.10.17 - 18:52
    Cool. Another opportunity for a demo.
    Do they stream anything from that event?
  • »23.10.17 - 18:58
    I don‘t think the X5000 is needed for this or that most declared it was. The new concepts (64-bit, SMP etc.) can be very well tested on G5 Macs. Or which concept is it that can be tested on the X5000 but not on a G5 Mac?
  • »23.10.17 - 19:06
    Posts: 2053 from 2003/6/4
    The only systems which really benefit from small footprint browsers are PowerUp and Efika MorphOS set ups.
    For my Efika I mostly use either Sputnik or AWeb APL. Then again it's not that often, that I use my Efika for web browsing. We have plenty better options...
  • »23.10.17 - 19:09
    Good question. They had the option of supporting new hardware, so they went that way.
    And the SAM460 was what really provided the initial PCI-E exposure (we don't really support 64bit functionality).
    I'd have been perfectly happy with 11,2 PowerMac support, as I already own one, but its looking less and less likely that that will happen. ;-(
  • »23.10.17 - 19:18
    Posts: 874 from 2003/3/4
    When I was watching that new IBrowse demo I happened to comment to an OS4 user that it looked no faster than the old 68k IBrowse on my G3 Pegasos.
    He replied that it looked much faster than the old *PPC-native IBrowse with emulated MUI3.9* on his AmigaONE/OS4. Suddenly the idea of resurrecting a decades-old browser made sense.
    (*Edited to clarify)
    [ Edited by KennyR 23.10.2017 - 21:32 ]
  • »23.10.17 - 19:40
    Did MorphOS on X5000 ever get demoed at Amiwest? I watched the stream at its allocated slot and they apparently cancelled it because they couldn't get the projector to work with its video output. Must have been really frustrating for Acill.
  • »23.10.17 - 19:49
    No, Acill decided not to do it as the quality of the display when feed into their equipment wasn't as good as he would have liked.
    He did give one on one demos to the attendees. I too would have liked to have seen a broadcast demo, but Paul felt it would have reflected poorly on MorphOS. And as his system is set up in a configuration that is supported by OS4, I can understand his concern, since apparently the display was fine locally.
    Maybe its time for AmiWest to consider upgrading their streaming hardware. I can understand the nostalgia value of a video toaster setup, but its not really adequate for processing the video signals from newer hardware.
    The displays from systems running OS4 were also quite blurry and distorted on the stream. For the most part, I could not make out the text in those images. It was adequate for rendering game displays, but for productivity applications it definitely left something to be desired.
  • »23.10.17 - 19:59
    zbysiuk
    Posts: 51 from 2006/8/4
    You're right.
    So, the entire Morphos x5000 project in the context of usefulness is unsuccessful unless one wants to buy new equipment with warranty or like Jim is nostalgic. I'm a supporter of PPC, but I try to be rational too - such a computer for 2k is a bit too much, especially since we have G5.
  • »23.10.17 - 20:08
    You're right.
    Well, I don't have to pay VAT, so my price is a little lower than the price most of you would get.
    And I do look at this as the last PPC system I will be purchasing.
    And short of trying to find a SAM460, I don't have any other options to use the new video card support (other than wait for an ISA shift - and I'm not that patient).
    As to success of the port (or lack of), well its already running on several X5000s and it hasn't even been released yet.
    And I intend to register a copy.
    If only a handful of people join me, that will make it more successful than the SAM460 port. ;-)
  • »23.10.17 - 20:25
    zbysiuk
    No hard feelings, I understend you perfectly. In my case 1k would be acceptable, so as you can see nostalgie has its price :)
  • »23.10.17 - 20:40
    No, I can understand the basic economic concerns involved in this purchase, when an 11,2 PowerMac would probably outperform the purchase of $2000 (or more) of new hardware.
    Its part of what makes the entire OS4 proposition seem so untenable.
    $2000 for an adequate system, or $500 for an inadequate compromise system versus $100< for an 11,2 PowerMac.
    Weird, huh?
    It IS time we moved to commodity hardware, because this custom stuff is a bad proposition.
    I'm just looking at the purchase of an X5000 as an collectable example of our last PPC stuff, I wouldn't recommend the purchase to another person.
    Its not rational. ;-)
  • »23.10.17 - 20:47
    I guess most nostalgics would prefer a G5 Mac to an X5000 ;-)
  • »23.10.17 - 21:14
    I suppose it depends on your focus.
    Until OSX you would not have caught me dead on a Mac.
    I REALLY didn't like the platform (too inflexible).
    But the G5s are pretty cool.
    And unlike many of you, I actually like the water cooled systems as they are still rather exotic.
    But as nostalgia value goes, I'm assuming that in he future the X5000 will have more of that for me, being Amiga specific.
  • »23.10.17 - 21:38
    Posts: 2794 from 2006/3/21
    That was exactly my thinking when I first thought about ordering my X1000. I was not expecting Trevor to be crazy enough to continue spending so much money on further AmigaOne designs and production costs. Later, when I learned that the X5000 was going to be produced, I still thought that the X1000 was a special computer, so I went forward with my purchase plans, even after Trevor advised me that I might be better off waiting for the X5000. If I had known for sure that MorphOS was going to be ported to the X5000, I would have cancelled my order for the X1000, and switched to a purchase of the X5000. Still, my X1000 is a nice system for running AmigaOS4.1FE, and some day within the next ten years, it might get a free copy of AmigaOS4.2, but I'm not holding my breath for that to arrive.
  • »24.10.17 - 18:18
    Posts: 1914 from 2003/10/19
    Hi everyone,
    Well the live streaming demo didn't happen because of the strange way they routed video out of my machine and into a series of switchers and a video toaster 2000 setup I think. It was causing all kinds of sync issues. I didn't want to show the public this crap so I refused to stream it.
    What I did do is demo it at the table and let it run most of the day Saturday. We tried again Sunday afternoon with the same issues. So I was sadly only able to show it one on one. It was very well received however and surprised a lot of people that looked at it.
    some STRANG to me at least things I noticed from "Amiga" users commenting on MorphOS
    1. They don't understand the panels?? I don't get this one, I explained they are just like Amidock and work quite a bit like them, once showing how to create a new one and add applications to it I THINK it cleared it up.
    2. SYS and MosSYS, many sisnt get that the system is split into its own complete dir structure away from what applications use when they install. Once I showed them it was a mirror of sys they liked it and thought it was a great idea, others asked why go to all the work reproducing a mirror of the system drawers, and when they crash OS4.1 and need to install from a rogue app I just laughed at them.
    3. They say they don't like the blue looking defaults and it confuses them, so I showed them a build I did making it look exactly like OS4.1 and it shuts them up a bit.
    4. I had to change out my R250X video card and put in a R230. They made life hell asking why newer cards are not supported. I mostly said because before the X5000 we didn't have a system that would take a newer card and it will now come once its public. This is one we really need to look at long and hard. I know Bigfoot is working hard on this and I am not to worried about it.
    5. The comments on how fast it is over 4.1 made me feel good. Boot up is a fraction of the time it take to boot 4.1 and that was so awesome to see people freak out when they say it boot in under 3 seconds compared to what it takes 4.1, which is considerable more time!
    Thanks to Bigfoot for trusting in me to show this. Amiwest is far from an AmigaOS 4 show. They want more AROS and MorphOS presence and I want to be able to give them all I can every year!! Next year I hope we can get things moving a bit sooner and be ready. I am also going to bring my own projector and video switching hardware. Its amazing just how bad the hotels service was!
  • »24.10.17 - 19:35
    > newer cards are not supported [...] because before the X5000 we didn't have a system
    The Sam460 has been supported since MorphOS 3.8, which was released 2½ years ago.
    > it will now come once its public. [...] I know Bigfoot is working hard on this
    I hope drivers for GCN-based cards (which is what OS4 users use primarily in PCIe) won't take long.
  • »24.10.17 - 21:11
    Acill, thanks for presenting and your interesting report from the show.
  • »24.10.17 - 21:40
    Andreas_Wolf...I hope drivers for GCN-based cards (which is what OS4 users use primarily in PCIe) won't take long.
    Unless they want to dual boot Linux, then they don't 😋
    Since very few of us have a PCI-E MorphOS system, the new driver aren't,t going to benefit many of us.
  • »25.10.17 - 13:12
    >> GCN-based cards [...] is what OS4 users use primarily in PCIe
    Hence "primarily". I believe most PCIe-based OS4 systems do not have Linux installed.
    My rationale is more about "them" who could become part of "us" than about "us" as of now, the potentially enlarged future "us" so to speak :-)
  • »25.10.17 - 14:01
    Spectre660
    Posts: 275 from 2015/6/30
    GCN cards function under Linux PowerPC .
    No gpu assisted 3D of video playback though .
    I use a GCN card .
  • »25.10.17 - 14:58
    I use a GCN card .
    Lack of 3D acceleration is a deal killer for me, but I should have pointed out that qualifier.
    In any case, since we aren't talking about extremely powerful CPUs, and I can find Terascale 2 gpus that clean the clock of some of those used on GCN based boards common in OS4 systems.
    As to the card Paul used, a Radeon R5 230, if I was going to use a Caicos based card, I would have picked the older Radeon HD 8490.
    It's faster.
    And the drivers Paul's system has will work with some lower end 8000 and 7000 series cards, as well as higher end cards like the HD 6870 (which can be had really cheaply right now and has very good OS4 and Linux support).
    Right now, GCN Gen1 doesn't really interest me, Gen2 and above (which Hans be Ruiter announced he was developing for), THOSE definitely have my attention.
    Particularly the RX 560, which is cheap AND powerful.
  • »25.10.17 - 15:30
    Spectre660
    As AmigaOS 4.x is my #1 OS ,I have what works best for AmigaOS 4.x as my default.
    Some interesting comments from SSolie in response to a question here
    http://www.amiga.org/forums/showpost.php?p=832137&postcount=7
    [ Edited by Spectre660 25.10.2017 - 11:44 ]
  • »25.10.17 - 15:40
    The only problem with that comment is its not coming from the guy developing the video drivers.
    But as they are gigantic parallel processors, there are some interesting possibilities offered by using the GPU.
    OS4 is now your primary OS? interesting.
    As I had the chance to explore AMD video cards from the R600 to GCN Gen2, one thing I did notice is that it really depends on what you're running with each gpu.
    The GCN cards really shine when combined with DX11.1 or 12.
    Under Open GL and older versions of Direct X, its a little less clear cut.
    If the GCN cards vended with the X5000 perform significantly better under OS4 than say a high end Northern Islands , I'd be somewhat surprised.
    BUT, GCN does shine in GPGPU applications, and its the future, so going that way makes sense.
    Again, these later cards will prove interesting.
    Mark mentioned to me awhile ago that he'd polled the Radeon R7 260X he had on hand and had gotten info back from it similar to what Hans mentioned.
    But de Ruiter is ahead of him, since Bigfoot insisted of supporting the intervening cards between our current support and the support included in 3.10.
    Obviously, since we have different primary OS', my criteria for video card selection will be different than yours. Luckily support for Northern Islands under OS4 is pretty good if I want to experiment with that.
    Linux? I'll probably install and after playing with it delete it or leave it unused.
    It takes to long to boot on NG hardware. And if I was serious, I'd just load it on one of my X64 systems.
    [ Edited by Jim 25.10.2017 - 11:10 ]
  • »25.10.17 - 16:07
