Home
Forums
Library
Links
Bounties
Login Block
Nickname
Password
Lost Password?
Don't have an account?
Register now!
Search
Advanced Search
Forum Index
User Forums
General Discussion
Pack Chrysalis beta for MorphOS 3.9 available
Page 3 of 3
1
2
3
Papiosaur
# 71
Posts: 2052 from 2003/4/10
Hi redrumloa,
It seems the problem is corrected, thank you for your return!
Easy2Install
www.meta-morphos.org
www.morphos-storage.net
13.04.16
05:54
redrumloa
# 72
Posts: 1424 from 2003/4/13
FYI I found a small problem. This creates a folder in Locale for dictionaries but is misspelled.
Overall, looking good.
17.04.16
20:01
Papiosaur
# 73
Hi redrumloa,
thanks a lot for your returns
i correct that this week-end and i will create and release a script to correct this problem.
Easy2Install
19.04.16
17:06
Page 3 of 3
1
2
3
