Pack Chrysalis beta for MorphOS 3.9 available
    anouk
    Posts: 15 from 2015/5/25
    Papiosaur, new version of SMBMounter is out. Will be cool if you add it too.
    http://aminet.net/package/comm/net/SMBMounter
  • »14.06.15 - 21:07
    WeiXing3D
    Posts: 327 from 2012/6/13
    jPV wrote:
    WeiXing3D wrote:
    What we need is an integration of E-UAE just like RunInUAE in the AmigaOS4.1.
    Would that be possible one day?
    It's been possible since the day 1, just look the bonus dir in E-UAE archive.
    That's the configuration that I'm using, but it's not quite the same. RunInUAE also lets you run m68k apps, just by dragging them on top of the RunInUAE icon.
    Please understand that this is not a complaint but a wish. I'm otherwise happy with E-UAE for MorphOS.
  • »15.06.15 - 03:29
    Cego
    Posts: 712 from 2006/5/28
    hmm, i think that should be possible too.
  • »15.06.15 - 13:16
    WeiXing3D
    @papiosaur - Will you now be skipping Pack Chrysalis 3.8 to go straight to 3.9? And if so, what is the targeted date of release.
    Thank you for your efforts and contributions.
    [ Edited by WeiXing3D 22.06.2015 - 09:33 ]
  • »22.06.15 - 18:32
    CountRaven
    Posts: 566 from 2007/12/11
    We are all waiting!
  • »23.06.15 - 05:16
    anouk
    Papiosaur wrote:
    Beta available :-D
    www.warmup-asso.org/download/pack/chrysalis_beta.iso
    Don't hesitate to test it and give me feedback to release the final version ;-)
    Thanks
    Clean MOS 3.9 in PowerMac G5. (Internet and OWB works fine!)
    Install Chrysalis, reboot and:
    Need Version 0 of bdsocket.library
    No internet!
  • »28.06.15 - 23:20
    Drako^lM
    Posts: 144 from 2005/8/10
    Mac Mini 1.5 + 3.9 + pack no boot
    Hardware :
    Power Mac G5 2.3 Ghz & MorphOS 3.18 & OSX 10.5
    Mini G4 1.5 Ghz & MorphOS 3.18
    BlaBla Team Member -> http://blabla.ppa.pl
    AmiParty Team Member -> http://www.chal.pl/
  • »28.06.15 - 23:37
    anouk
    Seems the image from: http://www.warmup-asso.org/download/pack/chrysalis_beta.iso
    is corrupted? anyone test it?
  • »30.06.15 - 21:50
    Papiosaur
    Posts: 2052 from 2003/4/10
    Hi anouk,
    i have launched the upload yesterday night and i have just look the size and the iso is not completed (i don't know why). I have relaunched the upload.
    Thanks for your return and sorry for that.
    [EDIT] The good size of the iso must be 769 696 744 octets.
    [ Edité par Papiosaur 30.06.2015 - 22:18 ]
  • »30.06.15 - 22:06
    anouk
    No problem Papiosaur, I´ll check tonight. I´m at job rightnow.
  • »01.07.15 - 15:00
    anouk
    Seems all works fine now.
    MINOR BUGS:
    Game > "Hex-a-Hop" cannot load font 'progdir:data//font.ttf'
    Game > "Wings Battlefield" new version had to be downloaded.
    Menu Prefs try to look at sys:, Emulation: and Games: so you've to assign the folders that you choose before at the installer to Emulation: and Games:
    Blender > The fonts are corrupted.
    [ Edited by anouk 01.07.2015 - 22:06 ]
  • »01.07.15 - 23:01
    Papiosaur
    Hi anouk,
    Thanks a lot for your returns!
    "Menu Prefs try to look at sys:, Emulation: and Games: so you've to assign the folders that you choose before at the installer to Emulation: and Games:"
    >yes, I have just see that yesterday, there is a problem into the installer script to create 2 variables to ENVARC: with the path for Games and for Emulation. The assignations are created but don't found this variables.
    I will correct that and the others bugs for the final release ;-)
  • »02.07.15 - 05:36
    Papiosaur
    New beta available this many corrections :
    @Anouk: try to resize Blender window after launch of Blender
    [ Edité par Papiosaur 05.07.2015 - 08:17 ]
  • »05.07.15 - 08:12
    anouk
    done! it works.
    BTW, Emulators folder is created perfectly in my WORK: partition but not Games folder and all games are on the root.
    Now, lets go to test the new beta....
  • »05.07.15 - 18:45
    Papiosaur
    done! it works.
    >cool!
    >My fault, an error creating archive...ISO corrected uploading...
    >Thanks a lot for your quick return :-D
    >I wait your others returns ;-)
  • »05.07.15 - 19:29
    anouk
    Well, seems all works perfectly now.
    Minor bugs in Menu Prefs:
    Stella emulator in Menu appears like "Sella" and I see Xump game two times in the menu.
    I´ve tested a lot of things and all works, smbmounter and UAE like a charm !!!!
    I think that this a good release candidate! :D
  • »06.07.15 - 22:00
    Papiosaur
    Thanks a lot anouk for this new corrections ;-)
    The final version is available :-D
    www.warmup-asso.org/download/pack/chrysalis.iso (759 959 552 octets).
    [ Edité par Papiosaur 11.07.2015 - 06:25 ]
  • »10.07.15 - 19:19
    Posts: 2794 from 2006/3/21
    Is this tested enough and bug free for me to use on one or two of the 5 MorphOS systems being displayed at the Amiga30 computer show this weekend?
  • »22.07.15 - 02:25
    Papiosaur
    Hi amigadave,
    yes, you can present this final version, it's better than nothing i think.
    If you have problems don't hesitate to say me.
    Thanks a lot to present Chrysalis pack and the association to this big event !
    Don't hesitate to send pictures of your tables and this event ;-)
  • »22.07.15 - 05:29
    Papiosaur wrote:
    Hi amigadave,
    Well I hope it is MUCH BETTER than nothing!
    I just completed the installation of Chrysalis on a fresh MorphOS3.9 install on my G5 PowerMac tower and am about to reboot it to see how it looks and works.
    Is there a lot of assign work that still needs to be done to get everything working that was installed, or was that done during the installation process?
    I have not tried your pack for a while, but remember from past pack's that some work was still needed to get all games and applications working after an installation.
    Edit: It Works! I was expecting a different wallpaper to be installed though, so when it booted to the original wallpaper, I first thought that the installation had failed, but it is all there. Now to do some customizing of the look before the show begins.
    Thanks Papiosaur for all your hard work.
    P.S. The emulators were installed to Sys: even though I specified a different directory during the install process.
    [ Edited by amigadave 23.07.2015 - 14:53 ]
  • »23.07.15 - 23:38
    Papiosaur
    Thanks amigadave for your return !
    "The emulators were installed to Sys: even though I specified a different directory during the install process."
    I will verify that, there is a problem with the volume requester (a bug of MorphOS?), when i click on the defaut path selected, there is no selection of the path, i must select another volume and select the good one after for the selection have been effective.
    Sorry for my bad english.
  • »24.07.15 - 05:22
