hello you all, I'm back!
Last june i have found an amigaone g3-se board to play with, got aos4.1 and all uptades (how dear!!!)
but not satisfied as always...
has anyone ever tried to install morphos on these boards, a1g3-se, or any other of the MAI logic ones?
best regards to all!
using Amiga since 1988
PPA1200 (Poor Portable Amiga 1200): BPPC-128MB,
BVision-CGX4, OS4.0, HD 10GB, slim DVD R/W, Asus VW161D
display, 3COM Lan PC card
AmigaOne G3-SE 600MHz, 1GB, Radeon 9200 256DDR, Muse 5.1, NEC USB PCI, RTL8139, OS 4.1 up6+ (optio
