Sopcast Player
    Cego
    Posts: 738 from 2006/5/27
    Hi there,
    is it possible to port this to MorphOS? It would be pretty nice to be able to watch sopcast streams with morphos.
    A lot of foreign sports events are broadcasted with sopcast :)
    http://code.google.com/p/sopcast-player/
  • »09.02.13 - 14:45
    Cego
    there is also a command line version:
    http://www.sopcast.com/download/linux.html
    But I don't know if the sources are available at all.  :-?
  • »09.02.13 - 15:01
    Samurai_Crow
    Posts: 198 from 2009/12/10
    Google Code projects are all open-source and the license given is GPL v2 which guarantees that it will always be open-source. Unfortunately, the GUI would have to be completely rewritten for using MUI since SopCast is written specifically for Linux.
    ::edit::
    It looks like it's just a GTK+ GUI wrapper for VLC written in Python. It would be better off rewritten from scratch.
    [ Edited by Samurai_Crow 09.02.2013 - 15:01 ]
  • »09.02.13 - 18:51
    Cego
    i dont know much about all this source code stuff, but does it look like much work? i guess its only about catching the stream sourcelink and add it to mplayer if it works that way, dont know  :-?
  • »09.02.13 - 19:12
    Samurai_Crow
    What I'm trying to say is that this project you've pointed out is just a GUI wrapper for VLC. VLC is a popular audio/video streaming software for Linux, Mac and I assume Windows as well. It is a program that does the same thing as MPlayer but supports some different formats.
    [ Edited by Samurai_Crow 10.02.2013 - 02:38 ]
  • »10.02.13 - 06:36
    Cego
    Is it generally possible to port Sopcast to MorphOS. the streams are actually played with mplayer or vlc. it would be pretty nice to have the best sport streaming platform on morphos.
  • »13.02.13 - 17:30
    Cego
    the problem is that sopcast uses sop:// links and mplayer cant handle them directly. sopcast is redirecting the stream to an player afaik. it shouldnt be that hard to write software for that purpose right?
  • »13.02.13 - 19:28
