Can't snapshot WORK window in MorphOS 3.1
    macsociety
    Posts: 57 from 2010/1/18
    Getting MorphOS setup the way I like it.
    Have the System, Ram Disk, other directory windows opening where I want them and able to Right Click in the window to save the ALL option so it saves where the window should be, etc...
    All other windows saved fine but no matter what I do, my WORK directory opens at the same stock place it did n fresh install of MorphOS 3.1 and is driving me nuts.
    What am I doing wrong?
    Just want to have this directory and window open on my desktop where I want it to.
    TJ
  • »25.10.12 - 18:02
    Papiosaur
    Posts: 2615 from 2003/4/10
    Hi macsociety,
    position of the window (and others prefs) are saved in a Disk.info file.
    This icon must be placed in the root of the partition.
    (Prefs of a window for a drawer are saved in the icon of the drawer)
    You must write this in a shell:
    copy sys:prefs/env-archives/sys/def_disk.info to work:disk.info
    After you could save position (and other pref) of your Work window.
    [ Edité par Papiosaur 25.10.2012 - 21:18 ]
  • »25.10.12 - 18:16
    macsociety
    Papiosaur,
    Thank you.
    TJ
  • »25.10.12 - 22:27
