Amiga-M to flip screens
    Fraggle
    Posts: 203 from 2012/9/2
    Hi all,
    Am I going mad or does Amiga-M (Or Apple-M) not switch screens like on 3.1?
    [ Edited by Fraggle 11.10.2012 - 13:18 ]
    Fraggle
  • »11.10.12 - 11:16
    Posts: 2095 from 2003/6/4
    It does: left CMD + m
  • »11.10.12 - 11:26
    Posts: 1099 from 2004/9/23
    This and more available hotkeys/functions can be changed/added in system preferences´ icontol panel.
    Geit
  • »11.10.12 - 11:30
    Fraggle
    Oh yep, sorted, it was set to mmb (which I don`t have of course) - fixed now.
    Thanks for that.
    edit: I think it may have been some kind of OWB conflict as amiga-M was bringing up the bookmarks.
    [ Edited by Fraggle 11.10.2012 - 13:39 ]
    Fraggle
  • »11.10.12 - 11:36
    No there are no conflicts, as right and left are different keys.
    You can define LCOMMAND, RCOMMAND or COMMAND. Usually LCOMMAND is used for such stuff, while RCOMMAND is/should be used only for menu items due historical reasons.
    Thats why keyboards with just one COMMAND key are a big problem. E.g. on an iBook there is only one COMMAND key, which is used for menu item control. Otherwise it would render menu hotkeys useless and they are more required as standard dictates several hotkeys for printing, about application, quit application, hide application, open file, ...
    Geit
    [ Edited by geit 11.10.2012 - 14:48 ]
  • »11.10.12 - 11:44
    Fraggle
    I see. I didn`t think of that as my chops are a little rusty and I never used menu shortcuts anyway.
    Fraggle
  • »11.10.12 - 11:49
    Posts: 2220 from 2003/2/24
    Yeah, Ultimate Pack sets it to MMB, which isn't that good, because it conflicts with several other things (Ambient's inline editing still defined to MMB too and doesn't work because of that, scrolling in MUI programs with MMB doesn't work either etc).
    Anyway with plain MorphOS it's defined as lcommand-m by default.
  • »11.10.12 - 13:01
    Miky060
    Posts: 694 from 2003/2/24
    Personally ever found MMB to switch screens a very powerful way to do it. LCOMMAND + M is slow, tricky ans less comfortable. I have been using MMB for 20 years and I would never change it.
    Ambient online editing can be easily configured/done holding LMB and personally is a trick that I use so many less times than switching screens...
    So Papiosaur, my vote goes to MMB even if this would not change the fact that now a lot of people will come here and tell the opposite  :-)
    [ Edited by Miky060 11.10.2012 - 20:53 ]
  • »11.10.12 - 17:52
    Fraggle
    MMB may be a better choice in the end but as an old schooler I just instinctively reached for amiga-M. I need to get a decent mouse for this Powerbook anways or Bigfoot will shotgun me into oblivion before I even see him hop around the corner
    [ Edited by Fraggle 11.10.2012 - 20:57 ]
    Fraggle
  • »11.10.12 - 18:35
    Miky060,
    While I understand your preference I suggest not to change default behaviour of the OS with the ultimate pack. I think it targets to novices and fresh installations - it should mess up as little as possible.
    If you look something up for MorphOS on google you'll probably find an answar to the default behaviour. If I google "morphos flip screen" I'll get the answer left CMD+m. Now if the pack changed this to MMB, this answer will not work and I will probably come to the concluson something is b0rked.
    Hence, better don't change OS behaviour within such a package.
  • »11.10.12 - 19:10
    Henes
    Posts: 507 from 2003/6/14
    The IControl preferences editor let you set several hotkeys for a single one action.
    So it's possible to keep the default lcommand-m and to *add* a mmb hotkey.
  • »11.10.12 - 20:57
    Miky060
    Henes,
    It's what I have and what would be a perfect solution for Ultimate pack.
    @Fraggle
    Are you using the powerbook without a mouse connected? You're a brave man!  :-)
  • »12.10.12 - 13:58
