USB Hubs
    Divinity
    Posts: 498 from 2009/9/8
    hi Guido :)
    I need to find a hub USB :)
    [ Edited by hooligan 16.07.2012 - 06:10 ]
  • »15.07.12 - 21:03
    boot_wb
    Posts: 874 from 2007/4/9
    Can you please edit the title, it's (almost) inaccessible from the front page.
    And, Ebay?
    I can confirm these USB hubs work at high (480mb/s) speed, I've bought them from this seller so can recommend them.
    Of the two I bought, the included psu's one worked fine (5v measured) the other wasn't sufficient to operate hub-powered devices reliably (4.8v measured).
    Unpowered these hubs also work at high speed perfectly well.
    Hope that helps.
    [ Edited by boot_wb 15.07.2012 - 23:44 ]
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »15.07.12 - 21:34
    @boot_wb,
    The price shown for the USB hub you provided the link to above is crazy. I hope you did not pay that price.
    Look at the prices for the many USB 2.0 hubs on this website:
    http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=392&name=Hubs
    Not all of them have 7 ports, but several of them do and are only a fraction of the price of the hub linked to by boot_wb.
  • »16.07.12 - 19:46
    Templario
    Posts: 549 from 2012/4/28
    Humm, if you live in Spain you have the problem altmost resolved now in summer the magazines give HUB USB or multireader cards, but here is the almost because sometimes the gif is more expensive than magazine but the quality, is poor but for 7-8 euros, is fine, I have a multireader card where the problem was in the cable, you have going to spain now in holidays.
  • »16.07.12 - 20:11
    boot_wb
    @AmigaDave
    Something's gone wrong there, they were about £6 or £8 when I bought mine. I suspect they've borked a bulk upload.
    That model of hub though.
    There are various sellers selling identical ones with different badges. They just happened to be the cheapest UK-based ones at the time I bought mine.
    [ Edited by boot_wb 16.07.2012 - 23:24 ]
  • »16.07.12 - 21:16
    @boot_wb,
    Glad to read that you did not pay the £96 for that hub, or what ever price is on that link now.
  • »17.07.12 - 20:29
