New pack Ultimate beta with a new installer
    Papiosaur
    Posts: 2615 from 2003/4/10
    I did not find any incompatibilities with OS 2.7
    there is one incompatibility (maybe more) :
    wbbstartup-script delete Showgirls v1.2 of MorphOS 2.7 !
    Are you making a new version for 2.7?
    yes, next version is in preparation, don't hesitate to do suggestions ;-)
    [ Edité par Papiosaur le 5/12/2010 16:41 ]
  • »05.12.10 - 13:39
    Papiosaur
    New pack Ultimate 1.6.4 is available for MorphOS 2.7.
    Installpack.lha (236 Kb).
    List of changes :
    - add Transfert (v1.0),
    - add Audio Evolution 4 demo,
    - add Ultimate update (old MOS Live upgrade) for updates,
    - add TSteel skin,
    - add SCANdal 1.5 DE,
    - add SimpleCat 3.22 FR,
    - add Meridian 3.11 FR,
    - add Transfer FR,
    - add Giana's Return v1.1,
    - add Gribouillis 2.6 r324 (archive standalone),
    - add Last.fm v0.5 plugin for AminetRadio,
    - add ColEm v1.0r6,
    - add GoogleTool v1.10.
    - add possibility to install 'Applications' on other partition different than sys:
    - update LHA (v2.7.10),
    - update http.stream Reggae class (v51.13),
    - update BoingPairs (v1.1),
    - update SCANdal (v1.5b2),
    - update LoView (v2.05),
    - update MPlayer (r32620),
    - update ScummVM (v1.2.1),
    - update GetVideo (v0.28),
    - update IceFileSystem (v2.2) version not registerd,
    - update youtube.js script for OWB,
    - update CRABUM (v1.4),
    - update SimpleCat (v3.22),
    - update Keymap sbar(v20.14),
    - update DriveLamps sbar (v52.8),
    - update of Wetter (v2.2),
    - update Elephant (v1.7),
    - modification of the screen bar module prefs,
    - modification of the Polynet prefs,
    - modification of the url shoutcast in ANR,
    - modification of the Ambient prefs,
    - remove of bad assign (TVPaint, RadioSrcipt).
    - remove of AmiTradeCenter,
    - correction of mimetypes 'x-adf' and 'x-dms',
    - and more...
    Please the readme file before install, thanks a lot for your returns.
    Thanks to all people help me in this project.
    Thanks to all developpers of software for MorphOS.
    Thanks to MorphOS Team for the best OS.
    [ Edité par Papiosaur le 23/2/2011 13:13 ]
    [ Edité par Papiosaur le 23/2/2011 13:23 ]
  • »23.02.11 - 09:46
    hooligan
    Posts: 1948 from 2003/2/23
    Ambient reports icons selected as "selezionato/i" because of Ambient preferences/Window/Status Bar. It should be translated into english.
    File in question is ultimate.lha -> prefs/ambient/ambient.prefs
  • »20.12.11 - 15:25
    Miky060
    Posts: 694 from 2003/2/24
    Probably my fault!
    But I think it's the only think I translated into italian. You can change it in Ambient Prefs->Window->Status Bar
  • »20.12.11 - 15:36
    hooligan
    BTW, great pack you got there.. its a lifesaver for "new user". Continue the good work!
  • »20.12.11 - 18:07
