NTFS USB disk problem
    mt12345
    Posts: 72 from 2011/4/4
    Weird. I connected ntfs usb 320gb disk drive and noticed that some folders (drawers?) are not visible in MOS, as if they don't exist.
    When I connect the drive to x86 linux machine everything is OK.
    Anyone experienced this? Should I reformat the disk to fat32? Or ext2?
  • »12.07.11 - 21:00
    MaveRickPL
    Posts: 73 from 2009/12/30
    Yes, reformat for Fat32. MorphOS have a problems with NTFS. You can read NTFS disk but You cant delete any files or save on this disk...
    MacMini & MorphOS
  • »12.07.11 - 21:32
