Screen brighter when connected with dvi
    _ThEcRoW
    Posts: 298 from 2008/10/27
    Hello all, the other day i noticed that when my mac mini is plugged via the dvi directly to the dvi input on my monitor, image seems brighter. With brighter i mean as if the controls of the bright adjust were upped. Anyone experienced this?
  • »15.10.10 - 11:27
    Golem
    Posts: 766 from 2003/2/28
    Brighter than? (DVI should give a better image than VGA)
  • »15.10.10 - 12:11
    _ThEcRoW
    Sometimes in boot, when selecting the boot disk i see a small, flickering on the screen. Other times don't. Just that the times when the flicker appear on the boot are when i notice the screen a bit brighter. If i somehow manage to get photos of it i will post here in order to show it, because i dont know hot to explain it better.
    Thanks in advance!!!
  • »15.10.10 - 12:22
    Fred_AROS
    Posts: 18 from 2010/10/11
    Maybe you?re monitor got auto adjust turned ON  8-) ???
  • »19.10.10 - 23:43
