TCP/IP stack (DNS) MorphOS 2.5 problem
    Divinity
    Posts: 532 from 2009/9/8
    found a "problem" in MorphOS 2.5 (There is not this problem in MorphOS 2.4) with TCP/IP stack, service DNS.
    For exemple, if I use my internal DNS server, and then I decide to change it with one or two external DNS for exemple, I select "save" in network preferences, but this has no results ... no way to ping/resolve an address name ... I must reboot MorphOS 2.5, then all works ok.
  • »07.08.10 - 15:07
    Golem
    Posts: 766 from 2003/2/28
    If you use the NetConfig command in a shell, you could probably avoid that reboot.
  • »07.08.10 - 19:19
