Ultimate Pack 1.6.0 for MorphOS 2.5 availlable in beta-versi
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    In HTML5 it works just fine here. Are you sure we're talking about the HTML5 mode here?
    Because, if you refer to the youtube.js script that allows to turn Flash youtube links (the ones not available as HTML5 yet) into HTML5, then it was indeed broken a couple days ago by youtube changes, but i've update it at my site ( http://fabportnawak.free.fr/owb/scripts/YouTube.js ).
  • »30.07.10 - 10:52
  • mk
    mk
    Posts: 72 from 2004/5/24
    23-Jul-2010
  • »30.07.10 - 10:54
    Posts: 12539 from 2003/5/22
    Strange.
    Yes, absolutely sure. 3 days ago it still worked here.
    I don't.
  • »30.07.10 - 11:05
    > 23-Jul-2010
    Huh? What's that to do with Youtube's own HTML5 mode?
  • »30.07.10 - 11:08
  • Fab
    Fab
    Ah, i see now. Youtube seems to have added a silly user-agent check since, and prevents from using HTML5 mode for the other browsers. Really stupid.
    Just go to settings and spoof as safari then.
    But in any case, the youtube.js script allows to play all of them by replacing flash with html5 builtin player. Current 1.8 version isn't totally complete regarding controls, but next version will be better: http://fabportnawak.free.fr/owbshots/builtin-mediaplayer-youtube-script.png
    [ Edited by Fab on 2010/7/30 15:19 ]
  • »30.07.10 - 11:18
    That's stupid indeed. Thanks for finding the cause of the problem.
    Yes, I know.
  • »30.07.10 - 11:33
    boot_wb
    Posts: 874 from 2007/4/9
    One minor thing I have found with PAk_Ultimate_1.6.0 is that the diretory (drawer) structure is fixed.
    Since I've now copied most things over to the locations I like them in, there are a few issues:
    Polyglot has problems - looking at the polynet_ng file in the WBstartup drawer (using ED) I see there are lots of paths already fixed (absolute paths). Additionally, the polynet_ng icon is set to open with a default tool (also set with an absolute path).
    The Add_Startup script also uses absolute paths.
    Would it be achieveable to have these set up using assigns?
    A relatively simple script could then be used to ask the user to set the assigns appropriately during the installation, which would then be used to create the Add_startup polynet_ng files in the WBstartup drawer appropriately (only a few of the programs supplied depend upon these files.
    Additionally, is AmiSSL required? The built-in stack seems to support all SSL sites which I've visited so far.
    Additionally, what is the purpose of the following script (in Add_Startup)?
    If Exists sys:applications/showgirls/showgirls
    delete >nil: sys:applications/showgirls all
    delete >nil: sys:applications/showgirls.info
    EndIf
    (This would appear to delete showgirls upon every startup, unless I'm confused...)
    Additionally, the font installation script for OWB errored out midway through (failed to unpack one of the fonts). could have been a problem with my individual download (corrupted file), but may be a problem with the availablility of the source...
    I hope the above is helpful, the pack itself is fantastic - so many utilities & programs which I probably may never have known about otherwise.
    Many thanks for everyone's (Papiosaur & all contributors) hard work.
    EDIT: Clarity
    EDIT: Correction: references to polyglot should be polynet_ng
    [ Edited by boot_wb on 2010/7/30 18:05 ]
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »30.07.10 - 14:01
    TiredOfLife
    Posts: 86 from 2009/10/13
    Cheers Fab, much appreciated. (unlike youtubes constant messing around)
  • »30.07.10 - 15:46
    _DaNi_
    Posts: 154 from 2010/5/4
    PAPI is possible a option for the ultimate pack 1.6 for choose to install IceIcons Pack and PatIcons Pack? The first, consumes less memory for example for efika systems
    http://amigaos0morphos.olympe-network.com/archives_packicones_eng_p1.html
    Thanks!
  • »31.07.10 - 07:37
    _DaNi_
    Download this pack, i think can be interesting for you ultimate pack :)
    http://www.mediafire.com/?269oj0moegw77m3
  • »31.07.10 - 09:03
    _DaNi_
    Yes is made by patbest, is a "strange" package, i haven?t install it, i am waiting the finished pack ultimate 1.6 with option for choose this icons but have some interesting stuff, like new datatypes for example :)
  • »31.07.10 - 15:02
    Papiosaur
    Posts: 2581 from 2003/4/10
    @ BootWB
    Absolute path is necessary for configure mimetypes.
    About ShowGirls, i have installed v1.2 in the pack, version 1.0 is obsolete and i just test if this old version exist and delete it at the first lauch of MorphOS with the pack installed.
    Concerning OWB Font, TCP IP must be ok for download alll truetypes fonts.
    I have removed AmiSSL of futur version ;-)
    Thanks a lot for your returns
    Papiosaur
  • »31.07.10 - 20:58
    TiredOfLife
    @papiosaur
    TVPaint asks for MorphOS 1.4 update when trying to load a pic.
    Nothing serious as I first thought, It's just a default directory.
    I thought the program was shutting down but it just goes behind the ambient screen and can be brought back to the front.
    Cheers
    [ Edited by TiredOfLife on 2010/8/1 15:45 ]
  • »01.08.10 - 11:10
    Papiosaur
    @ TiredOfLife
    I will see that, thanks
    A new beta version is available.
    List of changes:
    - remove of VLC and SimpleFind3,
    - add news versions of Tubexx and MPlayer,
    - add news icons of Patbest (IceFolders),
    - change PolyNet bar prefs,
    - add AutoDocReader in Development directory,
    - add many ScreenBar modules by default,
    - add ModernArt blanker by AmigaZeux,
    - add ZIP 68k in c directory,
    - add ShowGirls in French,
    - change of many mimetypes,
    - add new youtube.js script for OWB.
    Take the fun with MorphOS ;-)
    ps: an all-in-English version will be available soon...
    [ Edited by Papiosaur on 2010/8/2 14:51 ]
  • »02.08.10 - 09:49
    TrevorDick
    Posts: 130 from 2005/10/12
    Just downloaded and installed to a clear MorphOS installation on my Mac Mini 1.5. First problem I experienced was that I used the MOS default installation which creates quite a small System partition and large Work partition. No problem thought I, I could just perform a manual Mos2.5 update and make the System partition larger. No as easy as it seems. After a lot of trial and error I managed to create 2 equal sized partitions and re-installed MOS and then the Ultimate pack. So fa so good.
    It would be useful if the choice of partition could be selected when installing?
    Anyway, early days but looks like an excellent peice of work. Well done.
    TrevorD
  • »02.08.10 - 15:24
    TiredOfLife
    Been busy I see  :-)
    Nice work Papiosaur.
  • »02.08.10 - 15:34
    Great! How about a low memory version for the Efika after the English only version? I need to fix/replace my Mini's CD/DVD drive so I can upgrade to 2.5 and would like to see what this pack looks like on that and share in the fun other's are having with your pack.
  • »02.08.10 - 20:07
