Fresh Install and Booting From SATA
    magnetic
    Posts: 2129 from 2003/3/1
    Hey guys
    Now that we have SATA drivers for Morphos... i"m interested in doing a clean install of Morphos 2.5 onto a SATA drive. Can this be done from the current installer and can we autoboot from SATA? Thanks
    Thomas
  • »07.07.10 - 23:03
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    MorphOS itself can boot from a SATA system partition, but the Pegasos OpenFirmware can't reach a boot image on a SATA device. So you still need IDE (or netboot or whatever) for the boot img.
    [ Edited by Fab on 2010/7/8 4:47 ]
  • »08.07.10 - 00:47
    MarK
    Posts: 641 from 2004/1/25
    well, i use sata harddrives for some time now via IDE2SATA dongle and everything works pretty fine here :)
    bye, MarK.
  • »08.07.10 - 09:30
  • Fab
    Fab
    @Papiosaur
    I don't remember if the pegasos openfirmware detect usb massstorage devices. I strongly suspect it doesn't.
    [ Edited by Fab on 2010/7/8 14:56 ]
  • »08.07.10 - 09:44
    analogkid
    Posts: 706 from 2004/11/3
    @magnetic: You could use a CF-Card on the UDMA-Bus, just holding the MorphOS bootimage.
  • »08.07.10 - 10:53
    Posts: 236 from 2003/7/28
    @Fab
    An OF update to solve that would be nice :)
  • »08.07.10 - 11:39
    Posts: 12454 from 2003/5/22
    But that would have to be done by bplan, not by MorphOS Team.
  • »08.07.10 - 12:01
    @Andreas_Wolf
    Yep, but would be nice I guess. Although my IDE drive works fine.
    I do have many problems with USB keyboards on my Peg-2, it always types letters multiple times so I can't really type on it using USB keyboard.
    (in OF only).
  • »08.07.10 - 12:53
    Posts: 2727 from 2003/2/24
    Fab wrote:
    @Papiosaur
    I think the Efika "5K2" was the first...
  • »08.07.10 - 13:13
    Dreamcast270mhz
    Posts: 152 from 2009/12/8
    @magnetic
    There are SATA cards for macs which OF can boot from, maybe they would work in Peg if the chipsets are supported? Sonnet sells 'em.
    @thread
    IMHO, the IDE2SATA adapter defeats the purpose of getting a SATA drive, which is improved speed over cheaper per GB. I mean, SATA II has 6GB/s bandwidth, versus ~200mb/s or so for IDE? This is why we need more tower models :)
    My Macs:
  • »08.07.10 - 13:56
    You're confusing specifications with implementations of specifications. OpenFirmware is just a specification (IEEE 1275-1994), whereas Pegasos's SmartFirmware and PPC Mac's Firmware are different implementations of the OpenFirmware specification with different capabilities and extensions. Thus, PPC Mac's Firmware's capability to boot off SATA says nothing about Pegasos's SmartFirmware capability to do so.
    No, SATA2 has 3 Gbit/s, which is 300 MB/s (because SATA2 bytes consist of 10 bits each). Pegasos II has ATA/100 which is 100 MB/s.
  • »08.07.10 - 14:09
    Divinity
    Posts: 498 from 2009/9/8
    @all
    Are you sure It's better SATA via PCI 33mhz then IDE inside the Pegasos2, for bootstrap MorphOS volume ? ...
    I'd like an update of Open Firmware 1.2 of Bplan ... not only for SATA PCI cards bootable, but also for exemple to use USB Apple keyboard alluminum (I can use with Peg2 rev 2B5 and last OF 1.2 "only" USB Apple keyboard white, in Open Firmware) ... and sure for other many useful things.
    Damn, when MorphOS 2.6 for PowerMac G4 MDD/firewire 800 :) I'm here ready form months :) :) :)
    [ Edited by Divinity on 2010/7/8 18:20 ]
  • »08.07.10 - 14:20
    AFAIK the PCI slots and the southbridge share one and the same PCI channel on the MV64361.
  • »08.07.10 - 14:31
    Divinity
    Is there a good benchmark tool, utility for MorphOS to test I/O for SATA PCI vs PATA inside ?
  • »08.07.10 - 14:50
    jcmarcos
    Posts: 1178 from 2003/3/13
    What's this all about? You guys just want faster booting?
  • »09.07.10 - 04:52
