MorphOS 2.5 UPGRADE INSTALLATION FAILED?
    osco
    Posts: 680 from 2009/10/20
    "NOT DOS"????
    ID Offset Size Name Layout Type Detected Type Mounted As Mount Method
    2 0.188 GB 43.3GB DH2 MAC - MorphOS SFS DH2 Manual
    Drive DH2 Filesystem Autodetect DOS Type xxxxxxx Buffers 100
    The Wizard starts the upgrade process and when it tries to upgrade the system files it gets an error
    NOT A VALID DOS DISK
    INTALLATION FAILED  :-?  :-?  :-?  :-?  :-?
    [ Edited by osco on 2010/7/2 19:17 ]
  • »02.07.10 - 20:09
    March
    Posts: 91 from 2003/7/30
    Probably the HFS boot partition has not been detected properly. Could you post your full partition layout here? IWizard assumes that the boot partition is the first HFS partition it finds on disk.
    Marek Szyprowski ...... happy MorphOS, AmigaOS and Debian/Linux user ........
  • »03.07.10 - 04:29
    osco
    ID Offset Size Name Layout Type Detected Type Mounted As MountMethod
    0 0.000GB 128.0MB MAC - unknown - Disabled
    1 0.125GB 64.0MB DH1 MAC - MAC HFS - Disabled
    2 0.188GB 43.3GB DH2 MAC - MorphOS SFS DH2: Manual
    3 43.458GB 42.3GB DH3 MAC - MorphOS SFS DH3: Manual
    4 85.792GB 42.3GB DH4 MAC - MorphOS SFS DH4: Manual
    5 128.125GB 128.0MB MAC - unknown - Disabled
    6 128.250GB 104.6GB DH0 MAC - MAC HFS+ - Disabled
    7 232.886GB 8.0KB MAC - unknown - Disabled
    ID 1 & 6 Mount on boot
    Filesystem all Autodetect
    Dos Type for all xxxxxxxx
    Buffers 100  :-?  :-?  :-?  :-?
  • »03.07.10 - 11:58
    Golem
    Posts: 766 from 2003/2/28
    I don't suppose you've tried using SFSDoctor?
  • »03.07.10 - 12:30
    March
    Could you run HDConfig and check the type of the first partition (the 128MB one)? If it is Apple_HFS then change it to something else so IWizard would not try to mount it as Boot.
  • »03.07.10 - 13:02
    boot_wb
    Posts: 874 from 2007/4/9
    @Osco
    I notice that you do not have the 128MB 'padding' space between partitions. This is set up by the Mac partition program by default - I guess the MorphOS partition tool also creates these for compatibility with MacOS for dual-booting systems?
    Could this be the cause of the upgrade failure?
    On a side note, with reference to your e-mails to the mailing list (morphos@ml.morphos-team.net) on this issue, the mailing list convention is to use bottom posting (ie your reply should be beneath the original post). This makes things much easier for reading discussions. It also means people are more likely to reply to you, since they do not have to re-format your e-mails in order to reply. Just something I'd noticed that may prove helpful.
    Best Regards
    Rich
    [ Edited by boot_wb on 2010/7/3 17:32 ]
    [ Edited by boot_wb on 2010/7/4 2:31 ]
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »03.07.10 - 13:32
    March
    These 128MB padding partitions are not needed neither by MorphOS nor by OSX. They are created by default for some MacOS preOSX compatibility.
  • »03.07.10 - 16:34
    boot_wb
    @March
    Thanks, good to know that. Seems odd though as (in the days pre-OSX) 128MB would have been a fair old portion of the hard-drive. It still hurts to see it missing from the useable partioned space now :-)
  • »03.07.10 - 17:10
    Posts: 2070 from 2003/6/4
    Are you sure? When I set up 2.4 I did a dual boot installation w/o the padding partitions. It worked initially, but then the mini refused to boot OS X. I wiped out OS X then and eventually formated that partition with sfs (set up dual boot later again with an external fw drive, it's way more convenient).
    I also think I remember to have read that the padding actually is required.
  • »03.07.10 - 18:27
    osco
    The first partition is listed as "Apple Free" it's a padded partition
  • »03.07.10 - 19:02
    osco
    Hope this is the correct convention?
    The IWizard makes it to the Upgrade page
    Device Name: DH2
    Volume Name: System
    Capacity 43GB Free Space42gb MorphOS 2.4
    UPGRADE
    When "upgrade" is clicked a series of windows appear 16 of them
    The first two Copy
    not a DOS Disk
    Retry Cancel
    Next 14 Sys:tools Tools Iwiz
    not a DOS Disk
    Retry Cancel
    Then Final window annoucing upgrade failed
    I have a dual boot setup with MorphOS being the first to boot. I dont know how that came to be but it was welcomed because I rarely use the Mac side.. When using the Mac Side a a red stop sign appears on the desktop that the there is a problem with the boot disk..I click this meeage off and proceed with the Mac side. How does the wizard know a partition is the boot one and how does it read the system: to upgrade?
    [ Edited by osco on 2010/7/4 6:34 ]
  • »03.07.10 - 19:37
