menubar clock
    gdanko
    Posts: 28 from 2010/6/8
    Is there a way to get a menubar clock or anything like that?
  • »30.06.10 - 04:28
    Have you tried any of the 68k coded ones from aminet? I bet they will run without any modifications.
  • »30.06.10 - 04:45
    gdanko
    For some reason I thought this was built in. Maybe it's built into AROS instead??
  • »30.06.10 - 04:55
  • pOS
    pOS
    Posts: 220 from 2003/11/14
    Since MOS 2.0 there is an option in the System Preferences that shows a clock in menu bar on every Public Screen. Don't sit in front of my Peg atm, but think it was in IPrefs Section...
  • »30.06.10 - 05:01
    Posts: 2220 from 2003/2/24
    There's clock screenbar module. I think it was enabled by default, but check your screenbar module settings (RMB on screen depth gadget).
  • »30.06.10 - 05:56
    Posts: 3336 from 2003/3/5
    @gdanko
    Ehm, don't you have a clock already? It's enabled by default from 2.0.
  • »30.06.10 - 05:58
    gdanko
    Nope it isn't there. I want to say it was at one time but has since disappeared.
  • »30.06.10 - 10:41
    Could you make a screenshot? Sure it isn't simply disabled in the menu ?
  • »30.06.10 - 11:06
    gdanko
    I will take a screen tonight. Which menu would I find it in?
  • »30.06.10 - 11:53
    Golem
    Posts: 766 from 2003/2/28
    Right click the screen depth gadget, Clock should be listed under Modules.
  • »30.06.10 - 11:56
    AmigoHD
    Posts: 4 from 2009/10/20
    Where do I find this screen depth gadget?
    I am trying do enable some screenbar modules, too, but didn't find out how to do so far.
    I want to enable CPUGauge and some others in screenbar.
  • »01.07.10 - 09:34
    zukow
    Posts: 662 from 2005/2/9
    top-right part of screen and click RMB
  • »01.07.10 - 09:49
    AmigoHD
    thank you.
    but I don't get it. On which screen? Ambient menu bar?
    And RMB means? right mouse button?
  • »01.07.10 - 09:56
    zukow
    on all screens,
    yes, push right mouse button,
    http://www.youtube.com/watch?v=vNlOonqavGY
    [ Edited by zukow on 2010/7/1 15:05 ]
  • »01.07.10 - 10:04
    Golem
    Ambient screen will do fine, top right corner there is a gadget, place your mouse pointer over it and click the right mouse button.
  • »01.07.10 - 10:05
    gdanko
    I have no such gadget.
  • »01.07.10 - 11:26
    Golem
    Maybe you could provide us with a screenshot of your ambient screen?
  • »01.07.10 - 11:34
    gdanko
    I will.
  • »01.07.10 - 11:44
    AmigoHD
    It worked!
    Many thanks to zukow and golem.
  • »01.07.10 - 12:12
    Could you perhaps be having a screen size problem where the right side and/or the top edge of your screens are not displayed on your monitor?
  • »02.07.10 - 00:51
    gdanko
    That was it. Screen was configured to my old monitor size 1900 x 1200. Set the screen res correctly and I am ok. :)
    It's odd that MorphOS didn't detect the screen size and adjust accordingly. Maybe there is a setting somewhere for this.
    [ Edited by gdanko on 2010/7/2 8:05 ]
  • »02.07.10 - 01:10
