MorphOS 2.5 on PegasosII can't be installed [Solved]
    nexus
    Posts: 14 from 2009/4/24
    the MorphOS2.5 iso image boots up and you can choose language and keyboard.
    Then CDrom boots into Ambient but then nothing happens anymore.
    The Installer-Programm located in WBStartup doesn't start up and also not, when
    clicking on MophOSboot:MorphOS/data/bienvenue/bienvenue.
    The is file I downloaded from http://www.morphos-team.net/downloads.html seems to be ok. Also veryfing the CDR after burning shows no error.
    What could be the problem here?
    thanks,
    nexus
    [ Edited by nexus on 2010/6/7 7:51 ]
    Dye 'em black!
  • »06.06.10 - 15:39
    nexus
    ok, i found IWizard in Tools dir. Sorry for asking ..
    nexus
    Dye 'em black!
  • »06.06.10 - 15:45
    nexus
    ok. now updated and MorphOS 2.5 is running. great :)
    It seems OWB 1.8 is allready installed with MorphOS2.5, right?
    I just wonder because recently, there was a news that new OWB1.8 is out. Or is there a difference?
    However, that flash plugin is not included? Where can I get it from?
    Thanks,
    nexus
    Dye 'em black!
  • »06.06.10 - 16:44
    beworld
    Posts: 683 from 2010/2/10
    here : http://fabportnawak.free.fr/owb/
    My MOS ports
  • »06.06.10 - 16:56
    discreetfx
    Posts: 403 from 2003/7/26
    MorphOS 2.5 installs fine on PegII, I did a few days ago. Thought about registering it on PegII but chose to buy it for MacMini instead.
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »06.06.10 - 18:57
    Matt_H
    Posts: 30 from 2009/2/21
    It's the no-svg version that's bundled on the install image (good for Efika), and now the full version is available.
  • »06.06.10 - 20:23
    Posts: 12569 from 2003/5/22
    > It seems OWB 1.8 is allready installed with MorphOS2.5, right? I just wonder because
    The version that comes with MorphOS 2.5 doesn't support SVG. The SVG enabled version can be downloaded from Fab's website.
    Edit: Matt_H was faster. Damn ;-)
    [ Edited by Andreas_Wolf on 2010/6/7 1:48 ]
  • »06.06.10 - 20:46
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    It's indeed the SVG-enabled version, and it's also required for the MorphOS 1.4 users who'd like to run it, since the binary supplied on 2.5 ISO wouldn't run on 1.4 at all.
    Additionally, the standalone 1.8 archive comes with the userscript to fix overlay mode in youtube (couldn't be done for 2.5 ISO, since they broke it just before release).
  • »06.06.10 - 21:10
    You mean the MorphOS 1.4 users can't use the nosvg OWB 1.8 version from your website ;-)
  • »06.06.10 - 22:13
  • Fab
    Fab
    No, i mean the MorphOS 1.4 users can't use the particular version on ISO (because of the binary compression). The nosvg version on my site is also usable on 1.4.
    [ Edited by Fab on 2010/6/7 2:34 ]
  • »06.06.10 - 22:33
    nexus
    Thanks for the explanations and thanks to MorphOS-Team for their great efforts!
    However, I think something must have been wrong that the installer didn't pop up after startup. Anyway, now everything is working nicely!
    regards,
    nexus
    Dye 'em black!
  • »07.06.10 - 03:33
    nexus
    Another Question:
    Is there support for a "Silicon Image PCI Controller SATAII Sil3114" von in MorphOS 2.5 ?
    In the features description for MorphOS2.5 is written:
    SATA - Added support for SiI3x1x based 2-port PCI cards
    Although the description of Sil3114 says "4-port PCI card", it only has 2 interfaces for SATA devices. Therefore, I'm wondering if it can be used with MorphOS 2.5 and how i can check it :-)
    Thanks,
    nexus
    Dye 'em black!
  • »07.06.10 - 03:51
    Posts: 611 from 2003/4/11
    No, SiI3114 doesn't work with MorphOS 2.5. Some future 2.x release might support it, though ...
  • »07.06.10 - 19:12
    vulture
    Posts: 198 from 2008/2/4
    @pega-1
    Forgive me if this question is too naive, but you mean that only 2-port based Sil3x1x chipsets are supported thus 3114 is not, because it's a 4-port one? Which Sil3x1x are 2-ported and supported then? Any idea?
  • »07.06.10 - 19:52
    SiI 3512 and 3112, unfortunately that 3x1x info is a bit misleading ....
  • »07.06.10 - 19:56
    vulture
    @pega-1
    ah, thx for the clarification. So, if I may, one more question:
    would this work then?
    http://www.xcase.co.uk/2-Port-ESATA-2-Port-SATA-p/expansion-%20hx-431.htm
    And if so, ould both e-sata and sata ports be usable at the same time?
    Thx!
  • »09.06.10 - 06:41
    Golem
    Posts: 766 from 2003/2/28
    @vulture
    Only two ports will be usable, jumper settings on the card probably determine which.
  • »09.06.10 - 09:42
    vulture
    thx Golem!
  • »13.06.10 - 14:05
