Blanker graphics corrupt
    Cego
    Posts: 738 from 2006/5/27
    i have another problem with MorphOS2.4 that i didnt have with 2.2
    Everytime the system switches into blankermode after 10mins of inactivity the screen just shows corrupt graphics. i forgot the name of the blanker buts its the same as the one in OSX. i think its the one before or after the flames blanker.
    the only blanker that works is the picview one. the funny thing is that preview works fine.
  • »16.05.10 - 13:09
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Which resolution do you use?
  • »16.05.10 - 14:06
    Cego
    resolution is 1366x768 but its the same with predefined resolutions such as 1024x768 or 800x600
  • »16.05.10 - 15:28
    Golem
    Posts: 766 from 2003/2/28
    And depth? 16bit?
  • »16.05.10 - 15:51
    Cego
    24bit
  • »16.05.10 - 15:58
    amiades
    Posts: 231 from 2005/6/2
    I had corruption in non 4:3 modes... anyway, I have not tested this for quite a time now.
  • »17.05.10 - 05:33
    amyren
    Posts: 219 from 2010/5/15
    I do have a blanker problem. Not sure if it is the same problem as in this topic though.
    I did use the blanker "Feathers", and it worked fine until I noticed it stopped working last night.
    By coincedense maybe, but the only system change I have done since I saw it working is to add my keyfile to devs.
    Now the blanker never starts, and in the blanker prefs, the settings and preview buttons are disabled for this blanker. The other blankers seem to work as normal, and the buttons are enabled for the other blankers.
    When booting from the CD, the Feathers blanker works.
    I did try to locate and replace the related files, I found there are a file named System:MorphOS/Classes/Blankers/feathers.btd and also some files inside the System:MorphOS/Data/Blankers/Feathers drawer.
    I did replace all these files with the same files from the MorphOS 2.4 CD (and also checkes that they have the RWED flag). Then I rebooted, but still this blanker is the same.
    Are there any more files that needs to be replaced, or some config file I need to edit to make that blanker module work again?
    [ Edited by amyren on 2010/5/19 23:54 ]
  • »19.05.10 - 18:52
  • Fab
    Fab
    It's more likely this issue depends on particular resolutions/depths. Anyway, you should get debuglog (enable debug.sbar or just type getramdebuglog in a shell), and give the resulting log file.
    [ Edited by Fab on 2010/5/20 2:04 ]
  • »19.05.10 - 22:04
    amyren
    I sounds strange to me that it should have anything to to with my screenmode/depth, because I havent changed the screenmode since it was working.
    My current screenmode is 1024x768, 24bit. I have tried to set it to 16 bit, and also to 800x600, 24bit but this did not fix the problem.
    And the screenmode is the same when I boot from the CD, and then its working.
    Also, note that the "Feathers" is the only blanker that have this problem. All the other blankers works fine.
    I did make a debuglog, and I noticed the openpci.library message. I tried to copy the library back to libs, but then the system wants to rename the file to openpci.library-disable on next startup. Also it looks like there is a mui related fail at the end of the log.
    (Those two messages does not apear in the log if I boot from the CD)
    Here is my moprhos.log file:
    Setting Mac MAC
    Setting Mac Serial
    Setting up Keylargo ATA 3
    Setting Mac EDID
    SYS_HWEnableInt: IntID 0x0
    ABox 1.26 (17.11.2007) ? 1999-2007 by Ralph Schmidt, Emmanuel Lesueur, Teemu Suikki, Harry Sintonen
    SYS_HWEnableInt: IntID 0x4
    SYS_HWEnableInt: IntID 0x400001d
    keylargo_Init: ResBase 0x200b8c58 SysBase: 0x20001948
    keylargo_Init: done
    PMac_Init:
    SYS_HWEnableInt: IntID 0x4000027
    DRIVERIO_EVENT: spurious eventmask 0x40000000..no ObjectData
    DRIVERIO_EVENT: IntSignalMask 0x40000000
    ide.device@0: ATA-HD ST9808211A <DIRECT_ACCESS>
    LIB_Open from task $200b0138 "? AsyncInit - <ide.device> ?" context failed!
    ide.device@0: Mount <DH2>
    ide.device@0: Partition <DH2> DosType 0x53465300 BootPri 0
    ide.device@1: PIONEER DVD-RW DVR-K05 <CDROM>
    SYS_HWEnableInt: IntID 0x400003f
    usbscsi.device@0: Mount <usbscsi0>
    usbscsi.device@0: Partition <usbscsi0> DosType 0x4d534400 BootPri 0
    SYS_HWEnableInt: IntID 0x4000030
    SYS_HWEnableInt: IntID 0x4000001
    Intuition requester called from ramlib!
    "emu10kx.audio"
    Unable to open 'openpci.library' version 1.
    [OK]
    "emu10kx.audio"
    [OK]
    UserLibOpen : $VER: muimaster.library 20.6848 (10.10.09) ? 2008 Stefan Stuntz, PPC, MorphOS, DEBUG
    SYS_HWEnableInt: IntID 0x4000029
    MUI_LayoutObj : obj=0x21ff0aa8(0x202a1074_Virtgroup.mui)Type *I[6:38] 9/27 92x27 failed completely (min=254x27 max=10000x27)
    Titlegroup_DoLayout : oops... layout failed(left=9,top=27,width=92,height=27).
  • »20.05.10 - 06:30
  • Fab
    Fab
    I see nothing wrong in the log at least (it would still be interesting what triggers that layout issue at the end, but it's unrelated to your issue, anyway).
    The only reason i can see why it wouldn't initialize is a lack of video memory. Type "setenv TGLDEBUG 1" in a shell, run the blanker prefs again, and fetch the debuglog. It will tell us more.
    [ Edited by Fab on 2010/5/20 14:13 ]
  • »20.05.10 - 10:06
    amyren
    Normally I have only 32MB VRAM, but I did try to boot while holding the Alt key, so I get all the 64MB VRAM. The blanker does not work then either.
    This log here is from a boot with 64MB enabled:
    Setting Mac MAC
    Setting Mac Serial
    Setting Mac EDID
    keylargo_Init: done
    PMac_Init:
    "emu10kx.audio"
    [OK]
    "emu10kx.audio"
    [OK]
    TGL:[ 404]/resizeVertexBuffer() : Resizing vertex buffer to 256 entries
    TGL:[ 77]/mmDumpState() : MM:Statistics:
    TGL:[ 78]/mmDumpState() : | Name | Number/ Highest| Size(MB)/ Largest(MB)| Min | Max |
    TGL:[ 86]/mmDumpState() : | def| 59/ 59| 0.2716/ 0.2716| 80| 48384|
    TGL:[ 86]/mmDumpState() : | hash| 1/ 1| 0.0000/ 0.0000| 12| 12|
    TGL:[ 84]/glACreateContext() : GLAContext:0x22a5a020
    TGL:[ 190]/glAMakeCurrent() : MakeCurrent: SCR:0, WIN:0, FORCE:1
    TGL:[ 202]/glAMakeCurrent() : Context size: 192 120 (0x22b503d0)
    TGL:[ 211]/glAMakeCurrent() : glViewPort(0x22b503d0)
    TGL:[ 217]/glAMakeCurrent() : glViewPort done
    TGL:[ 437]/glAAllocDrawContext() : Initializing BITMAP mode(bm1:0x22e64eac)
    TGL:[ 469]/glAAllocDrawContext() : Done: GHandle:0x22b290ec
    TGL:[ 478]/glAAllocDrawContext() : Obtaining RAVE engine
    TGL:[ 524]/glAAllocDrawContext() : Depth buffer requested
    TGL:[ 539]/glAAllocDrawContext() : Creating Draw Context
    TGL:[ 549]/glAAllocDrawContext() : [RAVE]: Engine successfully initialized(context:0x22a5a094)!
    TGL:[ 587]/glAAllocDrawContext() : Configuring context
    TGL:[ 604]/glAAllocDrawContext() : Permedia2 compatible mode:0
    TGL:[ 611]/glAAllocDrawContext() : Vendor ID: 102 Revision: 0
    TGL:[ 672]/glAAllocDrawContext() : Maximum texture size:1024
    TGL:[ 682]/glAAllocDrawContext() : ExtendedClearBuffer available:1
    TGL:[ 692]/glAAllocDrawContext() : MultiTexturing available:1(4(3) units)
    TGL:[ 701]/glAAllocDrawContext() : GLBlending modes available:1
    TGL:[ 710]/glAAllocDrawContext() : Texture access available:1
    TGL:[ 719]/glAAllocDrawContext() : Stencil buffer available:0
    TGL:[ 728]/glAAllocDrawContext() : Color masking available:1
    TGL:[ 737]/glAAllocDrawContext() : cubemaps available:1
    TGL:[ 746]/glAAllocDrawContext() : combiners available:1
    TGL:[ 755]/glAAllocDrawContext() : dot 3combiners available:1
    TGL:[ 830]/glAAllocDrawContext() : Texture formats supported by the driver(13460):
    TGL:[ 831]/glAAllocDrawContext() : RGB24 :0
    TGL:[ 832]/glAAllocDrawContext() : ARGB32 :1
    TGL:[ 833]/glAAllocDrawContext() : RGB16 :1
    TGL:[ 834]/glAAllocDrawContext() : ARGB16 :1
    TGL:[ 835]/glAAllocDrawContext() : ARGB1555 :1
    TGL:[ 836]/glAAllocDrawContext() : A8 :0
    TGL:[ 837]/glAAllocDrawContext() : L8 :1
    TGL:[ 838]/glAAllocDrawContext() : AL16 :1
    TGL:[ 839]/glAAllocDrawContext() : LUT4 :0
    TGL:[ 840]/glAAllocDrawContext() : LUT8 :0
    TGL:[ 274]/glAInitDrawContext() : Initializing Draw Context
    TGL:[ 288]/glAInitDrawContext() : Setup:0x22a5a020(DrawContext:0x22a5a094, GLContext:0x22b503d0)
    TGL:[ 297]/glAInitDrawContext() : setup depth buffer...
    TGL:[ 299]/glAInitDrawContext() : setup depth mask...
    TGL:[ 301]/glAInitDrawContext() : setup fog...
    TGL:[ 303]/glAInitDrawContext() : setup alpha testing...
    TGL:[ 305]/glAInitDrawContext() : setup color masking...
    TGL:[ 307]/glAInitDrawContext() : setup stencil buffer...
    TGL:[ 309]/glAInitDrawContext() : setup polygon offset...
    TGL:[ 323]/glAInitDrawContext() : rebinding texture...
    TGL:[ 359]/glAInitDrawContext() : setup blending...
    TGL:[ 362]/glAInitDrawContext() : Done.
    TGL:[ 373]/GLGenTextures() : Allocating texture:1
    TGL:[ 373]/GLGenTextures() : Allocating texture:2
    TGL:[ 373]/GLGenTextures() : Allocating texture:3
    TGL:[ 373]/GLGenTextures() : Allocating texture:4
    TGL:[ 373]/GLGenTextures() : Allocating texture:5
    TGL:[ 373]/GLGenTextures() : Allocating texture:6
    TGL:[ 373]/GLGenTextures() : Allocating texture:7
    TGL:[ 321]/initializeFallback() : Initialized fallback texture
    TGL:[1029]/GLTexImage2D() : (7)format:0x1908, raveInternalFormat:0x4 (kQAPixel_ARGB32), width:64, height:256
    TGL:[ 101]/GLADestroyContext() : DestroyContext (type:3)
    TGL:[ 107]/GLADestroyContext() : Deleting Draw Context:0x22a5a094
    TGL:[ 114]/GLADestroyContext() : Deleting GHandle
    TGL:[ 461]/GLClose() : gouraud tgouraud flat tflat
    TGL:[ 462]/GLClose() : Tri: 0 0 0 0
    TGL:[ 463]/GLClose() : Fan: 0 0 0 0
    TGL:[ 464]/GLClose() : Str: 0 0 0 0
    TGL:[ 466]/GLClose() : clipped fans:0 vs unclipped fans:0
    TGL:[ 467]/GLClose() : clipped polys:0 vs unclipped polys:0
    TGL:[ 86]/mmDumpState() : | def| 67/ 68| 0.2773/ 0.2774| 24| 48384|
    TGL:[ 86]/mmDumpState() : | hash| 8/ 8| 0.0001/ 0.0001| 12| 12|
    TGL:[ 86]/mmDumpState() : | tmem| 1/ 1| 0.0625/ 0.0625|65536| 65536|
    TGL:[ 59]/free_all_textures() : Releasing texture with handle:0
    TGL:[ 59]/free_all_textures() : Releasing texture with handle:1
    TGL:[ 59]/free_all_textures() : Releasing texture with handle:2
    TGL:[ 59]/free_all_textures() : Releasing texture with handle:3
    TGL:[ 59]/free_all_textures() : Releasing texture with handle:4
    TGL:[ 59]/free_all_textures() : Releasing texture with handle:5
    TGL:[ 59]/free_all_textures() : Releasing texture with handle:6
    TGL:[ 59]/free_all_textures() : Releasing texture with handle:7
    TGL:[ 70]/endSharedState() : Releasing list hashtable...
    TGL:[ 72]/endSharedState() : Releasing texture hashtable...
    TGL:[ 84]/glACreateContext() : GLAContext:0x22ae45b0
    TGL:[ 437]/glAAllocDrawContext() : Initializing BITMAP mode(bm1:0x22b3de04)
    TGL:[ 469]/glAAllocDrawContext() : Done: GHandle:0x22b51e5c
    TGL:[ 549]/glAAllocDrawContext() : [RAVE]: Engine successfully initialized(context:0x22aea9cc)!
    TGL:[ 288]/glAInitDrawContext() : Setup:0x22ae45b0(DrawContext:0x22aea9cc, GLContext:0x22b503d0)
    TGL:[ 107]/GLADestroyContext() : Deleting Draw Context:0x22aea9cc
  • »20.05.10 - 13:09
    amyren
    Finally I managed to figure out what makes the Feathers blanker stop working. As expected it turned out to be my own fault in the end......
    In the basic MorphOS install the system:devs/datatypes is empty, but I had some datatypes copied from an older amigaos (winuae) installation. I did that earlier when testing som old 68k programs that seemed to complain about some missing datatypes and libraries.
    It then got down to three datatypes that makes the feathers blanker stop: jpeg, jfif-jpg and jfif-basic
    I did not expect this to happen. I dont know much about how MorphOS works, but I thought that the system itself was depending on the system files inside the MorphOS (MOSSYS:) drawer, and that the older file structure was there to support compatibility with older programs. And that the system therby could have two sets of datatypes, libs etc without risking old files making trouble for the operating system.
  • »23.05.10 - 08:27
  • Fab
    Fab
    In this case, jpeg files were probably matched by 68k jpeg datatype first, and since they're probably buggy, that should explain the failure somehow. :)
  • »23.05.10 - 09:52
