Another New User (Sort Of)
    gleng
    Posts: 38 from 2006/10/15
    Hmmm. I'm trying to figure out how to set up some development stuff on MorphOS.
    I've got Python installed and everything's working, so that's no problem.
    With regards to C/C++, I've installed the MorphOS headers and VBCC (I successfully built a hello world prog), but I'm not sure if I've set it up the right way, or where I should put all the PowerSDL bits. Is there a good howto somewhere on setting up a good dev environment? I've done bits of coding here and there on Linux, but Amiga/MorphOS development is completely alien to me.
    Any advice would be appreciated!
    [ Edited by gleng on 2010/5/18 0:11 ]
  • »17.05.10 - 20:02
    magnetic
    Posts: 2129 from 2003/3/1
    gleng
    I'd advise you to join the Morphos Developer Connection, as well as joining the mailing list and IRC. You can reach the devs with all these questions there..
  • »17.05.10 - 20:32
    Posts: 12454 from 2003/5/22
    https://morph.zone/modules/news/article.php?storyid=1619
  • »17.05.10 - 23:56
    gleng
    It looks like the Morphos Developer Connection doesn't exist any more. Am I being blind?
    Anyway, thanks to some help from Tokai on IRC, I've got gcc2 and everything else set up and working. I'll attempt to update gcc tonight!
  • »18.05.10 - 06:47
