osx responsiviness
    kickstart
    Posts: 227 from 2009/4/28
    Hi...
    Isnt the appropiate forum to ask but i prefer it, i have a little partition on my macmini for osx 10.4 and i want to make more responsive, i deactivate the useless dashboard but system still like a turtle.
    Anything else for disable and save resouces?
  • »24.03.10 - 00:15
    Velcro_SP
    Posts: 929 from 2003/7/13
    [ Edited by Velcro_SP 15.05.2011 - 09:02 ]
    Pegasos2 G3, 512 megs RAM
  • »24.03.10 - 05:46
    Posts: 1099 from 2004/9/23
    Same here. I have an iBook with 1.25 Ghz/1.25 GB and a mini with 1.5 Ghz/512 MB. The ibook is much faster on OSX than the mini just due the memory.
    Please also note that updating the harddrive will increase the speed.60/80 GB models are quite old and compared to modern 160/320 GB drives slow, so virtual memory is - expecially on low memory systems - faster with a new drive.
    In my case both system have the same drive model build in, so speed difference is just the memory.
    Geit
  • »24.03.10 - 08:33
    _ThEcRoW
    Posts: 298 from 2008/10/27
    On my mini i got excellent response when upgrading to 1gb. Also, some time before my ram stick went faulty, i noticed a bit of slow in general usage.
    Also, i'm planning on upgrading the hd, but ide drives nowadays are scarce. Will a sata drive with an adaptor make an improvement in speed over the mini original drive?.
  • »24.03.10 - 11:46
    analogkid
    Posts: 722 from 2004/11/3
    Yeah, try to increase the amount of memory... Recently, on a hardware meeting at geit, i've seen a Powermac G4 singlecore with 450 or 500 Mhz (don't quite remember), which had 1,5 gb RAM and a Radeon 9800, and it felt very fast, much faster than my Mac mini 1,5 1GB (ok, the Powermac had "only" Tiger installed, while i had Leopard on my Mac mini). Memory makes a huge difference.
  • »24.03.10 - 12:00
    Golem
    Posts: 766 from 2003/2/28
    Perhaps, but you likely wont be able to fit it in the case, WDs 2.5" PATA drives shouldn't be hard to find.
  • »24.03.10 - 12:07
    kickstart
    Maybe becomes slow in time but from the first day is a operating system too heavy, windows xp seems more agile sometimes, not mention to this multicolor circle that freezes everything.
    PS: i cant edit the typo error on the post subject, sorry.
    [ Edited by kickstart on 2010/3/24 20:10 ]
  • »24.03.10 - 16:07
    _ThEcRoW
    So, it's difficult to get an hd upgrade then?
  • »26.03.10 - 11:25
    Golem
    No.
  • »26.03.10 - 15:01
    Frek
    Posts: 15 from 2007/9/4
    Well, the multicolor circle is actually an side effect of something blocking execution.
    It pops up if the application hasn't voluntarily yielded for X no# of seconds, I believe it's around 15 seconds.
  • »26.03.10 - 15:21
