Disk Icons
    Rajinder
    Posts: 38 from 2010/3/24
    How do i change the disk icons
    I have the drive split into 4-partions
    Right clicking on the <system drive(where i installed MOS)> and choosing information/then clicking on PNG.icon will let me change that drive/disks icon..
    But the other partion/drives, i am unable to do the same
    Other partions are Apps,Games,Work
    I want to change the Apps+Games drive icons to others i have found in PatIcons.V2(BTW jolly good job creating these,most impressive)
    Thx Raj
  • »24.03.10 - 15:20
    Jambalah
    Posts: 820 from 2008/3/30
    Open your partition, select list mode and all files.
    You will find a "disk.info" icon: that is the one to change, the icon of that partition.
    Choose the icon you like (PatIcons are really awesome!) and name this icon"disk.info". Put in your partition, erasing or making a back up of the old one. And enjoy!
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »24.03.10 - 15:56
    Rajinder
    Thank you...
    i did try along these lines, but i named the icon same as the drive
    anyway thats working fine
  • »24.03.10 - 16:05
    Golem
    Posts: 766 from 2003/2/28
    You can also just select icon information for the drive then drag and drop a real icon into the window and click save.
  • »24.03.10 - 16:50
