Virtual monitor
    Tcheko
    Posts: 543 from 2003/2/25
    I am trying to setup a headless efika with a virtual monitor. So far, MorphOS boots without the graphics board but I didn't managed to log in with a VNC client.
    Any advice ?
  • »03.03.10 - 10:59
    Posts: 3311 from 2003/3/5
    Did you install a VNC server ? :)
  • »03.03.10 - 11:29
    Tcheko
    Ok. got it.
    You need to install the VNC server... Virtual Monitor is just a... virtual monitor and not a VNC server by itself.
    Thanks for advice.
    192.168.0.200 5900
    RFB server supports protocol version 3.8
    VNC authentication succeeded
    Desktop name is MorphOS
    Desktop size is 0 x 0
    RFB socket closed
    [ Edited by Tcheko on 2010/3/3 14:50 ]
  • »03.03.10 - 11:41
    jcmarcos
    Posts: 1178 from 2003/3/13
    Is that normal? Does this virtual monitor have any configuration, perhaps in its icon's tootltypes?
  • »03.03.10 - 13:11
    Tcheko
    Here is some tips about using virtual monitor + VNC server
    1) Start from a fresh installation
    I experienced some trouble with old/unperfect installation of MorphOS. Trying from a fresh install worked right away. It can saves lot of time !
    2) Remove all fancy theme and features like gradient, backdrop window & screen image. Go for a straight and clean MUI setup too. Stuntzi preset is a good start. VNC server uses Zlib compression scheme. Less details to compress mean faster VNC in the end. It can help a lot with Efika for example which have a low cpu power. For theme, go for malaxami for example.
    3) Copy Sys:MorphOS/Storage/Monitors/Virtual#? to Sys:MorphOS/Devs/Monitors
    Reboot or double clic the virtual monitor. This will add new mode to screenmode prefs.
    4) Install VNC Server
    Set a global password access. Don't forget to uncheck the local prompt. Once virtual screenmode selected, you can't see what's going on !
    5) Get your IP
    Open a shell, type ifconfig. Write down or remember the IP address. You will need it to logon with VNC client. You should set a static IP. If your DHCP lease change the IP, you'll have to scan your network to find the new IP.
    6) Check your VNC connection
    Try different VNC clients. I had some trouble finding one that worked well. Dunno why... I use Thight VNC.
    7) Open Monitor preferences and set ambient screen to Virtual 640x480@24. Remove Enhanced display checkmark if set. Save. Reboot & pray.
    8) Connect with your VNC client
    EDIT : I have just removed the radeon card... and Ambient can't open a screen. It seems you can't run without a graphic card on morphos 2.4 with virtual monitor...
    [ Edited by Tcheko on 2010/3/5 13:12 ]
    [ Edited by Tcheko on 2010/3/5 13:15 ]
  • »05.03.10 - 10:03
    Sprocki
    Posts: 131 from 2005/2/23
    That's it. You can skip configuring Virtual driver (steps 3 and 7) as it is non-functional. You need a graphics card inside the server to get any output to your VNC client. If you look at the serial log you can read that it stops here.
  • »05.03.10 - 22:16
    pampers
    Posts: 1068 from 2009/2/26
    Sorry for the lame question but that that virtual monitor does? I know the vnc thing but virtual monitor is a mystery for me.
    MorphOS 3.x
  • »05.03.10 - 22:31
    Sprocki
    Virtual is a graphics driver for allowing remote connection (such as VNC) without the need of a physically builtin grahics card.
  • »05.03.10 - 22:59
    CountRaven
    Posts: 566 from 2007/12/10
    Yeah this is how it should be but this is not working according to the posts of this topic.
  • »08.03.10 - 19:19
    Tcheko
    The bug have been reproduced by some members of the MorphOS team. Maybe it will be fixed in 2.5 release.
  • »08.03.10 - 19:51
