How do you stop a shell process?
    osco
    Posts: 680 from 2009/10/20
    Sometimes a process hangs in a shell window...How do you stop it and close the window? The DOS command "BREAK" needs a cursor? What if there isn't one in the window?
    Ctrl+C is the default for sending a Break signal to halt a process.
    A process that has been aborted this way displays ***Break
    in the Shell window. Ctrl+D halts execution of a script file.
    Just found it in the manual  :-D  :-D  :-D  :-D
    [ Edited by osco on 2010/1/20 11:11 ]
  • »20.01.10 - 14:06
    Golem
    Posts: 766 from 2003/2/28
    Press ctrl-c, next time maybe you could check the manual before starting another thread? Maybe post your findings to your blog?
  • »20.01.10 - 14:11
    Ruud
    Posts: 335 from 2009/2/2
    @Golem
    Didn't you know?
    MorphZone IS osco's blog  ;-)
    [ Edited by Ruud on 2010/1/20 16:25 ]
  • »20.01.10 - 14:25
    mihailod
    Posts: 170 from 2010/1/8
    Wait, I thought it was my blog!?!? :-D
    Seriously, I don't think there is harm in having simple questions and answers here. People Google their problems more often than looking into manual and stuff on this forum will be shown in the Google results.
    Is the MorphOS manual visible to Google? If not it should be so it can be indexed.
    This gives a mixed results at best:
    http://www.google.com/search?q=morphos+break+shell+process
    This is much better but you have to know to about Amiga:
    http://www.google.com/search?q=amiga+break+shell+process
  • »20.01.10 - 16:52
    osco
    What's a blog? Ok Golem googling "blog" hmmmm SAID well! @Ruud and Golem. In a way MorphZONe is my Blog..
    It is interesting to me my progress or lack of it with MorphOS.. I can't tell you how happy I am with Morph. My Home Page is MorphZone. My posts (blog) show some sucsess :) I read most of the posts.
    Thank-you again  :-D  :-D  :-D  :-D
  • »20.01.10 - 17:27
    Beamish2040
    Posts: 44 from 2009/4/2
    There's a manual?
  • »20.01.10 - 20:59
    mihailod
    I think he was referring to the Amiga DOS manual.
  • »20.01.10 - 21:16
    osco
    by Beamish2040 on 2010/1/20 17:59:59
    There's a manual?
    Help.lha
    Inline manual for MorphOS Shell Commands
  • »20.01.10 - 21:36
    jcmarcos
    Posts: 1178 from 2003/3/13
    Yes, Control-C sends a break signal to the process. Also, Control-D sends another different break signal, and you can send those signals from another console (knowing its process number) with the "break" command.
    But it's all a matter if the process actually LISTENS to those signals. One can write a program that locks itself deaf while doing something, not listening to anyone. Precisely, not listening to anyone is typical of crashed programs. Then, you should use a task manager to, hopefully, terminate the process (ugh!) and, more hopfully, attempt to recover the resources it was using.
  • »21.01.10 - 06:46
    osco
    "actually LISTENS to those signals. One can write a program that locks itself deaf while doing something, not listening to anyone. Precisely, not listening to anyone is typical of crashed programs."
    sounds like my wife :-D
  • »21.01.10 - 08:21
    Posts: 1099 from 2004/9/23
    OWB cut this post, and pushing back was a bad idea :)
    [ Edited by geit on 2010/1/21 11:30 ]
  • »21.01.10 - 08:28
    Open a new shell:
    Type "status"
    result is something like this:
    Process 1: Loaded as command: sushi
    Process 3: Loaded as command: status
    Process 4: Loaded as command: SuperApp
    SuperApp is the program we want to kill. Process number is 4 so type:
    Break 4
    Another status call will show you if the command reacted.
    Geit
  • »21.01.10 - 08:29
    _ThEcRoW
    Posts: 298 from 2008/10/27
    I encountered sometimes with programs that keep the shell window open. Pressing ctrl+c shows break, but i can't close the window, it keeps iconified.
    Tried with the task manager, but no luck. Are these processes un-exitable until you reboot?.
    Also another question a bit off topic: When a program crash(under os4emu), what's the way to get again into morphos workbench instead or rebooting?.
  • »21.01.10 - 12:29
    Golem
    You need to make sure parent task has quit, then it should be possible to close the shell window. To avoid having an iconified shell window on your ambient desktop you can just hide the window with ctrl-lalt-i (see icontrol prefs).
  • »21.01.10 - 12:47
    igracki
    Posts: 471 from 2003/2/24
    You can also use TaskManager or scout to break a task/process, they are more comfortable, since they have a gui!
  • »21.01.10 - 14:55
    Posts: 2220 from 2003/2/24
    ...and if we want to play around with status and break bit more :)
    If you want to break certain named process automatically from a script, you could do for example this:
    Status COM SuperApp > T:SuperApp.pid
    Break ? < T:SuperApp.pid >NIL:
    I use it to unmount smbfs shares from dopus menus/hotkeys :)
    And if you want to get more complete list of tasks in shell, you can use TaskList command. And make more brutal kills with iKill command.
  • »21.01.10 - 15:54
    mihailod
    Got this via emai from C.S.:
    "If you wish to "kill" a shell, use the command "mossys:c/iKill".
    Simple double click this program. After that the cursor was changed to a
    cross.
    If you now klick with this "cross" a shell - window, the Thread was
    finished."
  • »21.01.10 - 19:54
    Posts: 12569 from 2003/5/22
    I guess it's the same as with any program: Just switch screen.
  • »22.01.10 - 03:48
  • pOS
    pOS
    Posts: 220 from 2003/11/14
    You could also write it that way:
    Break >NIL: `Status COM SuperApp`
    Note the Backticks ! ` `
    The output of the command between is used as input for the break command. Kind of simple PIPE functionallity, introduced with AmigaOS 2.0.
  • »22.01.10 - 06:36
    Tcheko
    Posts: 544 from 2003/2/25
    IIRC, there is the freeze command. Open taskmanager, get the process ID and type
    freeze processidnumber
    in a shell. It will freeze the task/process. It doesn't remove intuition stuff like iKill nor free any ressources afaik.
  • »22.01.10 - 11:51
    _ThEcRoW
    MorphOS should let me change screen?. I mean when a os4 program crashes and all is showed is a black screen.
    P.D: What are the keyboard shortcuts for window switching?
    [ Edited by _ThEcRoW on 2010/1/22 14:20 ]
  • »22.01.10 - 12:12
    Golem
    Depending on the state of the system lcommand-m/n should work for that.
    None are defined by default, but have a look in Prefs -> IControl.
  • »22.01.10 - 12:46
