Watching youtube vids on Morphos 2.4 with owb
    Jambalah
    Posts: 820 from 2008/3/30
    I guess the mistake is in the complete path in wich MPlayer is.
    In fact you use "Sistema:Applications/Video/MPlayer". Sure that nothing is missing?
    I mean: I had that error using that command because I only indicated directory and not program. MPlayer is in a folder named "MPlayer". So unless you named "Video" the folder with the program MPlayer, you forgot to add "/MPlayer" complete the path.
    And if I remember well, v0.91 had no GUI. =)
    About link and page, the difference stands in:
    link make you watch the video with right mouse+ contextual menu+ watch video only on the link itself.
    Page allows you to watch video in the video page itself without pointing the link. You open a youtube page and right mouse+contextual menu+watch video directly on that page.
    Or clicking mouse in the thumbnail.
    I hope you enjoy video before midnight..  :-)
    [ Edited by Jambalah on 2009/12/31 18:02 ]
    [ Edited by Jambalah on 2009/12/31 18:05 ]
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »31.12.09 - 14:57
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    MPlayer 0.91 is really *old* (6 years old). It could probably not even stream (or at least without cache, so extremely dependant on network speed at best).
    So please use latest version, which is dated from september 2009. :)
    [ Edited by Fab on 2009/12/31 17:29 ]
  • »31.12.09 - 15:29
    DiskDoctor
    Posts: 306 from 2009/4/17
    I tried the python script first. Didn't succeed. Now It seems almost done with getVideo. I only wish to know where to get the rexxsyslib.library 68k version? It's neither on this site's downloads nor aminet.
    Please help.
    Was: Mac Mini PPC running MorphOS 2.4
    Now: Amiga Forever 2010 with AmiKit and AmigaSYS
    Not used: Icaros Desktop 1.2 (reason: no wifi)
    Planned soon: an OS4 system
    Shortly then: a MOS notebook (wifi is a must-have)
  • »01.01.10 - 13:24
    Golem
    Posts: 766 from 2003/2/28
    @DiskDoctor
    I see Amiga Forever in your signature, you should have a working copy of rexxsyslib.library there, copy it to your LIBS: directory and rename or delete the one located in MOSSYS:Libs.
  • »01.01.10 - 14:29
    Posts: 12539 from 2003/5/22
    http://aminet.net/search?content=rexxsyslib.library
  • »02.01.10 - 00:27
    _ThEcRoW
    Posts: 298 from 2008/10/27
    Thanks for the replies guys and for your patience... :)
    I managed to get it working before the new year, but haven't the time to post here, too many family compromises. Not it works ok, but there are some videos that won't play at all. It would ask for the type( i have for default the .flv) and when selected, be it mp4, 3gp or such, it gives an error saying it couldn't play the selected file. Seems that hd videos won't play at all. If anyone can clarify it better, would be much appreciated.
    Thanks in advance and happy new year to all!!!.
    P.D: It seems that i was using the wrong mplayer. Installing the latest seems to solve the problem, as the config files were all ok, and it was the reason i couldn't find any error  8-) .
  • »02.01.10 - 12:22
    Jambalah
    Happy New Year!
    Nice to hear you did it!
    For the videos, hd videos are played here. But with no sincronicity (yep, I'm listening The Police :-)) between sound and image.
    Try this link:
    Bruce Lee in Stop Motion
    I didn't chose a preferred filetype so I can select and hd works.. but.. =)
    I downloaded the file in hd and I have the same problem. Selecting one mp4 is much better.
    Flv plays ok.
    By the way, sometimes some youtube videos aren't played. Different formats? Or what?!?
    Enjoy!
    Pegasos II 1 ghz
  • »02.01.10 - 16:07
  • Fab
    Fab
    @Jambalah
    First, only a mini >= 1.42GHz has a chance to play it a full speed without synchronisation issue, but you should disable skiploopfilter: -lavdopts skiploopfilter=all (or lavdopts=skiploopfilter=all in conf/config).
    And then, depending on the HD files properties (bitrate, profile, ...), it might play flawlessly, or not.
    [ Edited by Fab on 2010/1/2 18:27 ]
  • »02.01.10 - 16:20
    Jambalah
    Thanks for the tips Fab!
    I didn't hope a hd video should be played at full speed + syncro on my peg. At least it works...
    I'm happy with the flv, too ;-)
    Pegasos II 1 ghz
  • »02.01.10 - 16:34
    _ThEcRoW
    So is recommended that no selecting ion the config file a specifically type, and leave the it asking you?. I will try that and see the result.
  • »16.01.10 - 12:18
