MORPHzone time slow by 15 minutes?
    osco
    Posts: 680 from 2009/10/20
    I have repeatedly corrected the time on my system?
    last time 7hrs too fast?ll
    [ Edited by osco on 2010/1/10 21:56 ]
  • »11.01.10 - 00:07
    jcmarcos
    Posts: 1178 from 2003/3/13
    Don't you realize that you express in a way that nobody else but you understands? Really, put your mind blank, imagine you are someone that knows nothing about what you're talkng about, and read your own phrase. Then decide, honestly, wether it's understandable or not.
  • »11.01.10 - 10:49
    MarK
    Posts: 641 from 2004/1/25
    exactly, i'd like to help, but i don't understand...
    bye, MarK.
  • »11.01.10 - 11:11
    osco
    Ty for the replies. Ok putting my mind blank....normal condition :)
    Please look at your Morphos system time. You see it at the top right of your Ambient screen?
    Ok? Now Post to Morphzone. OK? Refresh and notice the time of your post you just made. Ok?
    Does the time agree with the time on the Ambient window?
    On my system it is off about 15 minutes.
    Ie: Time on my Ambient screen 09:55 posted time 09:40 fifteen minutes slower?
    Hope it makes sense now?
    Another problem with time is that it is set and saved correctly with prefs. When system rebooted at another time ..System time is incorrect again by a factor of 7 hours..
    Laters 8-)
    [ Edited by osco on 2010/1/11 10:40 ]
  • »11.01.10 - 12:43
    osco
    My system time 09:57 my post time 09:43 :-?  :-?  :-?  :-?  :-?
  • »11.01.10 - 12:45
    Posts: 1073 from 2004/9/23
    Open a shell and type:
    Copy sys:MorphOS/s/network-startup to s:
    Ed sys:s/network-startup
    A new window opens with a text file. Move the cursor to the end and add the following line:
    run DETACH MOSSYS:c/Setclockntp save
    Now push the save item in menu or the button and close the window. After this the system time will be set on each reboot.
    Geit
    [ Edited by geit on 2010/1/11 15:58 ]
  • »11.01.10 - 12:55
    Golem
    Posts: 766 from 2003/2/28
    See geit's post for the fix, but could you confirm if you've booted OSX before the system time changes?
  • »11.01.10 - 13:22
    osco
    System is now correct to the second!!! Ty
    Alas Morphzone off by 13 minutes.
    Will reboot into MacX and then reboot into MorphOS
    [ Edited by osco on 2010/1/11 10:55 ]
  • »11.01.10 - 13:53
    osco
    @geit
    Ty again for the fix!
    "run DETACH MOSSYS:c/Setclockntp save" What does that command do?
    1: DETACH MOSSYS ?
    2: C/Setclockntp save ?
    Where in the archives are the answers?
  • »11.01.10 - 14:08
    The line sets your system time by using internet time servers thats all.
    You can open a shell and type
    SetClockNTP
    this will set the time instantly, but only until the next reboot.
    Geit
    [ Edited by geit on 2010/1/11 17:12 ]
  • »11.01.10 - 14:11
    Posts: 12472 from 2003/5/22
    > 1: DETACH MOSSYS ?
    No, the blank is the separator.
  • »11.01.10 - 17:07
    koan
    Posts: 303 from 2005/11/21
    @osco
    There are many people on this forum who are not native English speakers who would gladly help you if they could understand WTF you are saying. For example, "Ty" ? OK, I finally sussed out that it's short for Thankyou but I can't imagine many places where this "abbreviation" is in common use. Could you put just a tiny bit of effort into your posts to make them readable ?
    run = shell command to start another task
    DETACH = argument to run to detach the task from the parent process
    MOSSYS: = an assign to the location of the core MorphOS system, usually InstallDrive:MorphOS
    c/Setclockntp save = the command to save the network time
    MOSSYS:c/Setclockntp is the full path to the command. Setclockntp was new in MorphOS 2.4 IIRC and there is no official documentation for it.
    run is pretty much the same as the original AmigaDOS run command.
  • »11.01.10 - 18:08
    osco
    Understood Thank-you for your explanation of the Code. What is WTF? only kidding 8-)  8-)
  • »11.01.10 - 18:35
    It was new with 2.3 :-)
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6407&forum=3#64729
  • »11.01.10 - 20:55
    magnetic
    Posts: 2129 from 2003/3/1
    umm stay off the drugs??  ;-)
  • »11.01.10 - 22:45
