Catweasel flipper driver progress?
    redrumloa
    Posts: 1424 from 2003/4/13
    Has there been any progress on the catweasel flipper MOS drivers? I'd really, really likt to have the game port working!! :-D
    Imagine using these controllers with mos-stella!
  • »29.10.03 - 20:37
    Posts: 979 from 2003/6/28
    I use an Amiga keyboard with the cw keyboard drivers and runs really great !!! But i want CW keyboard support on firmware :(
    The catweasel is suppoted with an lowlevel subtitute for amithlon that seems to run on MorphOS, but i heard about only 1button support :(
    And no drivers of the SID part, i have a SID on the Catweasel MK3.
    Could be nice a little hard-hack for can make a hardware reset with CTRL+Amiga+Amiga ( when MorphOS crash for example :P ).
  • »29.10.03 - 23:33
    redrumloa
    That may be good enough! Do you have any links handy? :-?
  • »30.10.03 - 15:01
    td741
    Posts: 224 from 2003/4/2
    I've used the Amithlon version, it worked (last time i checked) but at the time I last tried, it was single button and I was hoping to use my CD32 pads. :(
    You should be able to find the Gameport driver here: http://www.vmc.de/amithlon/
    Steph
  • »30.10.03 - 15:32
