Customized toolbar ala Korni
    JohnFante
    Posts: 158 from 2006/9/4
    Any ideas on how I create a cool looking toolbar like this one that Korni has made/uses?
    http://www.soft-port.dk/Toolbar.jpg
    The default tool bar is usefull but a bit dull :-)
    Thank you in advance!
  • »12.12.09 - 14:11
    XzIt
    Posts: 250 from 2005/1/19
    thats polynet, http://polymere.free.fr/index_en.html
    Xzit
  • »12.12.09 - 16:47
    Korni
    Posts: 472 from 2006/2/23
    This one you linked isn't mine :). I use an Ambient panel and Statline.
  • »12.12.09 - 17:18
    JohnFante
    Sorry about that!
    I took it from one the previews you supplied with your package of three skins so I thought is was yours.
  • »13.12.09 - 07:57
    Jambalah
    Posts: 820 from 2008/3/30
    The guilty is me!! :-)
    I am still playing with polynet bar (since the new update uses the transparence) and I like to "mix" things.
    In fact, in that grab you can see a half polynet bar attached to half ambient panel, plus a retouched clocktoy ;-)
    But this is pure polynet bar:
    Polynet Bar
    Of course, I used some tricks.... :-)
    I've realised a "tutorial" to do that. But the link is broken... =(
    I will do another as soon as I could.
    [ Edited by Jambalah on 2009/12/20 17:00 ]
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »20.12.09 - 14:58
    JohnFante
    Cool :-) and thanks!
    Looking forward to the tutorial ...
    Btw.: If you need serverspace for the tutorial I would be glad to supply :-)
    [ Edited by JohnFante on 2009/12/20 18:53 ]
  • »20.12.09 - 15:50
