Pegasos2 and 2 gb ram
    vulture
    Posts: 198 from 2008/2/4
    try "memtest VERBOSE EXTENSIVE LOOPS=10" for a more accurate result. Right now as it is it seems you get no errors, but there obviously is a problem as you can't actually use more than 1gb of RAM.
  • »16.12.09 - 04:58
    Divinity
    Posts: 532 from 2009/9/8
    Hi vulture,
    thanks, this is the result:
    boot:> memtest VERBOSE EXTENSIVE LOOPS=10
    Allocated memory at 0x2AB378C0 -> 0x7F92D0BF, 1423923200 bytes
    Writing 0x00000000...
    amd I have now, always in about two seconds : Ram Disk: 97.1MB free, 300.0KB/97.4MB used
    any ideas ?
    thanks
    [ Edited by Divinity on 2009/12/16 21:06 ]
  • »16.12.09 - 19:03
    Golem
    Posts: 766 from 2003/2/28
    Divinity wrote:
    this is the result:
    Well.. that is no result, what did you do to verify it was actually working on those other OSes?
    Found this for Linux.
  • »17.12.09 - 02:23
    Divinity
    Hi Golem,
    this one tool http://www.mupper.org/memtester in not working very well as many other peg2 users with > 512Mb ,so your idea is very good but I need a tool right for the high memory.
    I have also found this one url (useful) http://www.powerdeveloper.org/forums/viewtopic.php?t=1301&postdays=0&postorder=asc&start=0
    I remember you, I have rev. 2B5 with last Smart Firmware 16/12/2005.
    Do I need to test with Crux ?, other memtester tools ? Any ideas ?
    thanks a lot!
    [ Edited by Divinity on 2009/12/17 11:23 ]
  • »17.12.09 - 09:22
