MorphOS 2.4 - max partition size with SFS
    Get27
    Posts: 90 from 2004/8/23
    Hello,
    i have to changed my hard drive and i plug a 500GB HD into my Pegasos2.
    It's correctly reconized by OF and MorphOS (HDConfig).
    I made partitions when a bubble said "This partition is too large for the selected filesystem" (SFS).
    The bubble disapear when size is under 124GB.
    In MorphOS 2.4 release notes say :
    SFS : Fixed broken disk formatting code with disks larger than 124GB
    So, what is the maximum partition size with SFS ?
    Wich FileSystem is better ?
    Thanks
    PowerMac 3.5, G4 1.0GHz DP, 1GB ram, 80GB HD + NAS, Radeon 9600 128MB Mac, 1680x1050
    PowerMac 7.3, G5 2.3GHz DP, 4GB ram, 160GB HD + NAS, Radeon 9800 128MB PC, 1680x1050
    Amiga 500+, Vampire 500v2+, HxC Floppy
  • »26.11.09 - 15:02
    Golem
    Posts: 766 from 2003/2/28
    128GB here.
    <128GB
    Guess that depends on your needs, using FFS/SFS/PFS3 here.
  • »26.11.09 - 15:19
    Crumb
    Posts: 738 from 2003/2/24
    @golem
    I haven't tried to use it massively for MorphOS apps but couldn't ext2/3 partitions work correctly? It should allow big partitions and files.
  • »26.11.09 - 19:57
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Ext2/3 partitions wouldn't have this limit, and as a bonus, they also support >4GB files. The drawback being they don't handle all amigaos attributes, of course.
  • »26.11.09 - 20:24
    Crumb
    @Fab
    perhaps marek could hack ext2 to add amigaos attributes (even if it stopped being compatible with ext2/3), add a new filesystem identifier and label it "MarekFileSystem"
    Another option would be increasing the sizes allowed in the SFS structures so it allows bigger partitions and files and label it SFS3 (add a new filesystem identifier so SFS partitions are handled through normal SFS...).
    I think future MorphOS versions will need an updated filesystem as standard.
  • »27.11.09 - 08:37
    Get27
    +1
    [ Edited by Get27 on 2009/11/27 11:18 ]
  • »27.11.09 - 09:17
    Ruud
    Posts: 335 from 2009/2/2
    @Crumb
    I'm pretty sure it's been said that SFS can't be changed to support larger partitions due to the way its designed.
  • »27.11.09 - 12:15
    Posts: 12569 from 2003/5/22
    ...and retain 100% compatibility to SFS at the same time.
  • »27.11.09 - 20:38
    Ruud
    Ah, ok I see.
  • »27.11.09 - 20:56
