Silly questions.
    kickstart
    Posts: 227 from 2009/4/28
    Hi!
    Well im trying to install cpugauge, seems very easy, i follow the readme but when i reach this step im lost:
    "Now click with the right mouse button on the screen depth gadget to open its
    context menu, go to "Modules" and select "Refresh". Now open the context
    menu again, and go to "Modules" again and select CPUGauge from the
    modules shown there. CPUGauge should now appear in the Screen title
    bar."
    Whats the "screen depth gadget"?
    Another one... where can copy the .mcc mui libraries? theres some mui folders at the system partition.
    And the silliest one... I change my background ambient sometimes but this time i dont remember how =( (amnesia or sth) i find how to change boot picture, skin themes... but no luck for the simple background.
    Thanks and sorry for this crap.
  • »25.11.09 - 06:42
    Tcheko
    Posts: 543 from 2003/2/25
    Upper right corner of the screen. There is a gadget to switch screen.
    SYS:Classes/MUI can be a good place to store third party mcc. Don't put anything inside MOSSYS:.
    Hmm. From ambient, go to menu Preferences / Ambient Prefs.
  • »25.11.09 - 06:50
    kickstart
    Believe it or not Menu-Settings-Ambient appears empty, just the requester.
    Thank for the answers =)
  • »25.11.09 - 07:01
    kickstart
    One of my silly questions about where copy the .mmc mui libraries is due to aminetradio... when i execute aminetradio menu bar becomes red a second and nothing more, wheres the problem?
  • »25.11.09 - 15:30
    Golem
    Posts: 766 from 2003/2/28
    Somewhere on your system would be my guess, so check ANR requirements again, and make sure you have everything you need installed, perhaps check with Snoopium.
  • »25.11.09 - 15:35
    Jambalah
    Posts: 820 from 2008/3/30
    ehm... silly answer...=)
    Did you checked if there is an address with wich AminetRadio could search for a radio station?
    I mean: if you open AminetRadio settings and click on "Shoutsearch" there is an address in the proxy textbox?
    A question: when you click on Menu-Settings-Ambient you haven't the Ambient window settings appear with all the possible configurations?
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »25.11.09 - 16:26
    kickstart
    @golem
    Yes, i forgot snoopdos, nice application for it, the requirements of aminet radio are in general for amigaos 3.1, morphos come with mui and ahi default by example, aminetradio only tells the lack of bettersgring.mcc (if i remember exactly).
    @Jambalah
    The problem is aminetradio never executes, just the menu bar appears in red a second and never more, thanks... answers are always welcome.
  • »25.11.09 - 20:02
    Golem
    kickstart wrote:
    @golem
    MorphOS does not include all the 3rd party MUI classes...
  • »25.11.09 - 21:21
    kickstart
    Well... aminetradio needs...
    NList.mcc downloaded and copied to sys:classes/mui (empty drawer)
    busy.mcc originally located on sys:morphos/classes/mui
    hotkeystring.mcc downloaded and copied to sys:classes/mui
    render.library, guigfx.library, mpega.library located on sys:morphos/libs (original ones)
    After that the same "error", menu bar red a second and nothing more.
    Edit: After a reset runs fine.
    [ Edited by kickstart on 2009/11/27 3:18 ]
  • »27.11.09 - 01:45
    kickstart
    Now aminetradio works but what do you have at the shoutsearch option to search online music?
  • »27.11.09 - 02:38
    Posts: 2564 from 2003/2/24
    http://classic.shoutcast.com
  • »27.11.09 - 03:53
    jcmarcos
    Posts: 1178 from 2003/3/13
    kickstart wrote:
    [edit]
    NList.mcc, busy.mcc, hotkeystring.mcc, render.library, guigfx.library, mpega.library... After that the same "error", menu bar red a second and nothing more.
    Hey, could someone knowledgeable tell us why he had to reset after adding these components? Because some of them are related to MUI, and MUI only gathers its components once? If so, exactly when?
  • »27.11.09 - 05:57
    Golem
    Hard to say, but if someone managed to reproduce this, maybe we could find out.
    No.
  • »27.11.09 - 06:23
    kickstart
    @jcmarcos
    choose between casualty or 30 mins limit
  • »27.11.09 - 14:34
