Danish characters in MorphOS 2.4 - think it is a bug
    JohnFante
    Posts: 158 from 2006/9/4
    I have installed MorphOS2.4 on my MacMini and it works like a charm :-)
    The only problem I have is that I do not have danish characters in Ambient. I have them fine when I write things in forexample OWB but in the menus they are replaced by strange caractercombinations..
    At first I tought that it was some kind of missing font but since I can write them fine I now think it is a bug.
    Anbybody else having similar problems?
    [ Edited by JohnFante on 2009/10/15 17:27 ]
  • »14.10.09 - 06:57
    koan
    Posts: 303 from 2005/11/21
    Menu font is set differently ?
    Check MUI settings for Ambient.
  • »15.10.09 - 22:25
    JohnFante
    I talked to one of the developers and it looks like the problem is caused by wrong encoding of the danish characters in Ambient - in other words som kind of bug.
    The danish locale file is encoded in UTF-8 but needs to be encoded in iso-8859-1.
    Since very few (at this point :-)) uses the danish locale it slipped through.
    I will be fixed with the next release. :-D
  • »16.10.09 - 06:24
    kolla
    Posts: 105 from 2003/4/22
    It wont be a fix, it will be a workaround for the real problem.
    -- kolla
  • »16.10.09 - 13:50
