MorphOS 2.0 iso
    Tcheko
    Posts: 544 from 2003/2/25
    I need a MCC only available in 2.0 iso which is no more available.
    Would it be possible for the morphos team to publish 2.0 & 2.1 iso ?
    I need the Nlist.mcc coming from the 2.0 iso btw... This one is stable for ATC.
    Cheers,
    Czk
  • »15.03.09 - 17:23
    Daff
    Posts: 251 from 2003/4/5
    NList.mcc 20.121 works here with ATC 1.1308. But you can send my an email if you want a previous version.
    http://obligement.free.fr
  • »15.03.09 - 17:56
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    MorphOS 2.0 iso isn't linked, but it's still available:
    http://www.morphos-team.net/morphos-2.0.iso
    [ Edited by Fab on 2009/3/15 20:21 ]
  • »15.03.09 - 18:21
    Golem
    Posts: 766 from 2003/2/28
    The 2.0 iso is still available.
  • »15.03.09 - 18:22
    Tcheko
    Available but not linlked.
    A link to old iso would be nice :)
    Thanks you all. Got the MCC now.
    Czk
  • »15.03.09 - 20:38
    Simon
    Posts: 809 from 2008/7/6
    ATC seems to work fine here without the need for using an older Nlist ?
    Altough it did took some time before I got it working, but I don't remember why anymore...
  • »16.03.09 - 05:18
    Posts: 12569 from 2003/5/22
    > why anymore...
    Was it because you first took the version from Aminet instead of the newer one from the ATC website? ;-)
  • »18.03.09 - 01:16
