X11
    xyphoid
    Posts: 870 from 2008/7/11
    Is it possible to get an X11 set up for MorphOs (or is there on already
    in the works?) similiar to Open Office for Mac. This would be a huge
    advantage for our next release. Isn't AOS4.x using somthing like this
    for their Abiword?
    Just noticed
    previously discussed here
    [ Edited by xyphoid on 2009/1/24 0:39 ]
  • »24.01.09 - 03:34
    Posts: 1087 from 2003/3/24
    There are three bounties open one X11 Server and two wrappers one for X11 and one for GTK.
    All are open but when the funds rise maybe there will be a Coder that take the bounty.
  • »24.01.09 - 10:55
    xyphoid
    I C. What's with the 2003 January deadline :-?
  • »24.01.09 - 13:30
    CISC
    Posts: 619 from 2005/8/27
    Considering you noticed there already was another thread on this matter I suggest people read that thread (my opinion on the matter should be fairly obvious then) instead of just rehashing everything in this one...
    - CISC
  • »24.01.09 - 14:13
    Posts: 2220 from 2003/2/24
    There are several old X11 servers for Amiga and at least some of them still work on MorphOS. X-server is for display/input only, so you'd still need to compile the actual programs for local computer or run them from remote computer. I just tried to run OpenOffice on remote computer and controlled/viewed it on MorphOS screen with Xami. Worked fine although bit slowly.
    I used to use X-server on A1200 about 10 years ago. I ran Netscape from our school's computers remotely (AmiWM gave it Amiga look too ;). There also were ported apps like Gimp for Amiga too, so you could use them locally without any remote connections. Check old Geek Gadgets for more... there was Amiga port of twm window manager etc to get some control to windows etc.
    But in the end it wasn't that fun for long. Purely native apps are much more pleasant.
  • »02.02.09 - 15:06
    zukow
    Posts: 662 from 2005/2/9
    xami is nice prog but it can't connect to machines with new Xorg.
    I use NxServer very often to connect to my linux server.
  • »02.02.09 - 17:44
    CountRaven
    Posts: 566 from 2007/12/10
    +1
    Would prefer a native cool office suite for MorphOS.
    Although it seems a bit of fun to try all that X stuff.
    MorphOS should come first but after all for some apps missing, Linux is always installed and I think there is OpenOffice available at least @ OpenSUSE? Right? So it is just a click in that multi boot menu....
    [ Edited by CountRaven on 2009/2/3 10:55 ]
  • »03.02.09 - 08:49
    SoundSquare
    Posts: 1214 from 2004/12/1
    can you all take that in consideration please ?
  • »03.02.09 - 11:49
