(E)UAE on MacMini + MorphOS (speculation thread)
    TheMagicM
    Posts: 1220 from 2003/6/17
    This may be a "yes" or "no" type answer... guessing/speculation etc is ok.
    When MorphOS comes out for the Mini, will it run UAE (whatever current incarnation) as fast as a A500 with sound synced up properly? I'm assuming the Mini will have enough power for that?
  • »02.01.09 - 16:41
    Painkiller
    Posts: 128 from 2007/11/19
    I'm hoping it would, but I'm also hoping that PPC JIT bounty would be set.
  • »02.01.09 - 16:51
    analogkid
    Posts: 719 from 2004/11/3
    Even a Pegasos with G3 could do it, so should the MacMini.
  • »02.01.09 - 18:31
    Posts: 917 from 2004/1/24
    "could" is the magic word indeed. I dare anyone to supply a .uaerc with settings that make "Hybris" (or "Battle Squadron") play fluently with sound and no frameskipping on the latest e-uae (I guess the one Fab did is). On a peg2/g4 :-)
    [ Edited by Stevo on 2009/1/3 1:16 ]
  • »02.01.09 - 22:14
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Ok, here are two, then. :)
    Note that you have to use the non-sdl version, which is quite faster (especially in overlay mode).
    Also note these config files are supplied in the archives (a500, a500-hires.conf, a1200.conf, a1200-hires.conf).
    With Hybris, this one requires about 65% cpu on a Peg2/G4
    kickstart_rom_file=PROGDIR:kick13.rom
    immediate_blits=no
    cpu_type=68000
    gfx_width=320
    gfx_height=256
    gfx_lores=yes
    gfx_linemode=none
    gfx_center_horizontal=smart
    gfx_center_vertical=smart
    gfx_fullscreen_amiga=no
    gfx_fullscreen_picasso=no
    cpu_speed=real
    chipset=ecs
    fastmem_size=1
    chipmem_size=1
    floppy_speed=0
    joyport0=mouse
    joyport1=joy1
    amiga.screen_type = custom
    amiga.use_overlay = yes
    This one, doesn't use lowres mode and requires about 70% (always with hybris).
    kickstart_rom_file=kick13.rom
    immediate_blits=no
    cpu_type=68000
    gfx_width=640
    gfx_height=256
    gfx_lores=no
    gfx_linemode=none
    cpu_speed=real
    chipset=ecs
    fastmem_size=1
    chipmem_size=2
    floppy_speed=0
    joyport0=mouse
    joyport1=joy1
    [ Edited by Fab on 2009/1/3 1:16 ]
  • »02.01.09 - 23:10
