MOS update not working
    klapdeur
    Posts: 132 from 2003/6/28
    HELPPPPP
    guys when i try to update my mos with the new one (for peg1)
    the system starts but i cant move my mouse please any help would be
    great same i have now with mos 1.4 1.3 is working fine
  • »29.03.05 - 19:08
    SoundSquare
    Posts: 1214 from 2004/12/1
    did u also update the bootpeg1.img file ? replace your old one by the new one.
    Only update modified files, not the whole thing. So your prefs will be safe.
  • »29.03.05 - 19:30
    klapdeur
    yes i did the only thing that is working now is mos 1.3.
    1.4 and 1.4.2 are not working anymore not even from booting from cd. mouse is not responding anymore
    im despared please help me out here :-?  :-?
    as soon i boor from the boot image from above 1.3 the mouse is dead.
    i formatted my hd but still the mouse is dead tried another one but still no luck. is there anyway to reset the firmware envarc
    maybe that helps
    [ Edited by klapdeur on 2005/3/29 23:35 ]
  • »29.03.05 - 20:19
    merko
    Posts: 328 from 2003/5/19
    Is it a PS/2 mouse or a USB mouse?
  • »29.03.05 - 20:43
    klapdeur
    its a ps/2 mouse and a usb (with ps/2 connector ) from logitech
  • »30.03.05 - 03:04
    MarK
    Posts: 641 from 2004/1/25
    On my P2/G4 system with 1.4.4 refused to work my usb devices. I tried my usb flash memory and my camera. Nothing worked. When I switched back to 1.4.2, it started to work again. Could it be caused by the poseidon 'downgrade' in the latest 1.4.4 release? (iirc, I have read somewhere, that in the 1.4.2 was 2.2 poseidon, while in 1.4.4 is 2.1)... I will investigate more later.
    Bye, MarK.
  • »30.03.05 - 03:27
    Robin
    Posts: 741 from 2003/2/24
    IIRC,on a peg1 you cant boot from cd when you've
    set your boot-file to boot.img.
    Since the file boot.img on cd is for peg2.
    You could try to set your boot-file to bootpeg1.img .
    (IIRC it's setenv boot-file bootpeg1.img ramdebug)
  • »30.03.05 - 04:43
    weiseb
    Posts: 215 from 2003/3/29
    I am not sure about 1.4.2 (I think it was 2.1) but
    1.4.4 came with 2.1. I had to install the update
    to get 2.2 again.
  • »30.03.05 - 05:23
    Posts: 154 from 2003/4/22
    Bye, MarK.
    Every MorphOS 1.4.x integrates Poseidon V2.1. However, newer version is avlaible at http://www.platon42.de/poseidon.html.
    Nevertheless, devices like mice, keyboard ... should work fine.
    Your sincerly
    MorphOS Rulez !
  • »30.03.05 - 05:24
    Posts: 34 from 2004/4/8
    your problem is simply. just remove the usb devices, upgrade poseidon, then everyting works again. i have the same problem with my Smartjoy adapter. Remove it and when you installed poseidon update plug it back.
  • »30.03.05 - 08:56
  • Leo
    Leo
    Posts: 426 from 2003/8/18
    Any reason why Poseidon 2.2 is not included in MOS 1.4.4 ?
    Sounds like it would have avoided a lot of trouble/questions...
    Licence problem again ? (as for FXPaint Lite)
    Leo.
  • »30.03.05 - 13:33
    Posts: 979 from 2003/6/28
    Poseidon is evil, he is the owner of the sea...
    Let's see what says platon42, maybe he is another unpaid by Genesi...
  • »30.03.05 - 16:45
    Robin
    Bugfixes are free ... New features and updates cost money ;-)
  • »30.03.05 - 17:53
    klapdeur
    :-D its working again? thnx for the help guys. it was that smartjoy thing and a busted memory sim i had to replace and now it works fine here
  • »31.03.05 - 04:02
