SNDF 2004 Japan
    Hawk
    Posts: 204 from 2003/12/29
    I just took some pictures at the SNDF 2004 - Tokyo.
    SNDF2004 Tokyo pix
    Pegasos II G3@600Mhz (no fan) 512MB RAM (1 slot)
    -- Maxtor 6Y120P0 120GB, 7200 rpm -- ATI Radeon 7500 - (64MB, TV-out)
    -- Minuet Slimline PC case -- MorphOS 1.4.5 + Gentoo
    EFIKA
  • »21.10.04 - 17:53
    bbrv
    Posts: 750 from 2003/2/14
    Thanks for the pictures David!
    R&B :-)
  • »21.10.04 - 18:03
    Posts: 979 from 2003/6/28
    Very interesting, a few photos only and no seen an offical report (thanks David, Its normal that you didn't writed a long report since it requires a lot of time and probably you dont have that) but this must be a news item. It seems that MorphOS was not mentioned, a bit sad, but its normal considering that MorphOS hasnt still japanese support (no UTF8 and not supported a lot of different text encodings, this must be one of the next goals I think) and will not be interesting too due to still using an api with very important lacks as memory protection and others. So probably, it will be a lot more important with the internationalitation of the OS, qbox and probably others as a good web browser with the compatibility level like Mozilla Firefox, Opera and Webcore/KHTML. MorphOS must has advantages but supported those important things that others do.
  • »21.10.04 - 22:04
