Posts: 2732 from 2003/2/24
Go here:
http://www.gentoo.org/doc/en/handbook/index.xml... and choose what version of the handbook you want to view (like the printable PPC version).
Then click on the "Installing Gentoo" link and simply follow the instructions step by step!
Use the "Universal LiveCD".
Get going with: boot cd /boot/pegasos root=/dev/ram0 init=/linuxrc looptype=gcloop cdroot
If your Pegasos is connected to Internet, you should, when you get to the stage where you are configuring the compile options, add ACCEPT_KEYWORDS="~ppc" to /etc/make.conf before emerging the kernel. This will enable the very latest packages, and with that, things like the Gigabit Ethernet among other things.
Of course, this info (and more) is available on David Holm's website:
http://dev.gentoo.org/~dholm/ppc.htmlMorphOS is Amiga
done right!
MorphOS NG will be AROS
done right!
