Matt Dillon's project
    DethKnight
    Posts: 139 from 2003/6/24
    http://distrowatch.com/01724
    I am ; therefore you are
  • »29.06.04 - 15:55
    ChatDEau
    Posts: 248 from 2003/4/4
    @DethKnight
    What's with Matt Dillon ?
    Fred
  • »30.06.04 - 00:45
    DethKnight
    finally a pre-release is out
    (Mr. Dillon made D.I.C.E.)
    Now he makes a flavor of BSD
  • »30.06.04 - 10:43
    Posts: 917 from 2004/1/24
    It seems that only a x68 binary is available yet :-(
  • »30.06.04 - 12:15
    Posts: 199 from 2004/2/9
    DO you mean a Pegasos version is available or will be soon ? :)
  • »30.06.04 - 12:19
    DethKnight
    not necessarily, but that has never stopped the wishful thinking
  • »30.06.04 - 20:30
    Posts: 979 from 2003/6/28
    http://www.osnews.com/story.php?news_id=153
    Dice C compiler for the Amiga :)
  • »30.06.04 - 21:44
    poundsmack
    Posts: 1346 from 2003/6/7
    what makes this implementation of BSD any better than anyothers. is this not jsut a fork or freeBSD?
    "Poundsmack, official morphzone thread creator" -LorD
    "Wanna be lord of the avatars." -JKD
  • »30.06.04 - 23:35
    Tcheko
    Posts: 543 from 2003/2/25
    Not just a fork. Kernel is completly rewritten with a different philosophy. You can find more information here : http://www.dragonflybsd.org/goals/
    Seems really nice. Matt Dillon is a BSD Master. If I remember well, he rewrote all the VM code and expunged all the kludge written for years...
    Another BSD falvour :)
  • »01.07.04 - 10:13
    Looks a better BSD flavour...
  • »01.07.04 - 12:21
