Network not working after 3.20 update
    JohnFante
    Posts: 163 from 2006/9/4
    I have updated to (from 3.19) to 3.20 on my X5000 but I get an "Device or unit failed to open" error and the network is down.
    You can see the error here:
    https://www.dropbox.com/scl/fi/rolnrjlcfkf9wu5u9nk3c/Network-error.jpeg?rlkey=rzi1m2zymykr4h2rf5ekfw4it&dl=0
    I use DHCP and have never had any issues before. My - very straight forward - network settings are:
    https://www.dropbox.com/scl/fi/7jne1n88239bd4sw4s8ab/Network-settings.jpeg?rlkey=nhcjtmrpjmp4pcfarjbtsyj26&dl=0
    I have checked and it is not the cable :-) There is also a green light on the ethernet port on the back so there is signal to it. I just will not open.
    Any suggestions?
    [ Edited by JohnFante 16.06.2026 - 17:51 ]
  • »16.06.26 - 16:50
    pampers
    Posts: 1070 from 2009/2/26
    Had similar issue but it went away when I set the static IP.
    MorphOS 3.x
  • »17.06.26 - 07:51
    JohnFante
    Setting it to static IP gets rid of the error but still no connection in my end.
    Maybe a buggy driver. Or?
  • »17.06.26 - 16:59
    Posts: 478 from 2019/5/9
    Driver on its own is not buggy - qoriq_eth.device works very well on my Mirari.
    There should be some isuue connected to X5000.
    In Release notes there are:
    Qoriq_eth New
    Ethernet driver for Mirari & CyrusPlus/X5000. Replaces the CyrusPlus onboard driver.
    Try to check if you have right driver selected in settings.
    [ Edited by sailor 17.06.2026 - 18:12 ]
  • »17.06.26 - 17:08
    Posts: 50 from 2020/10/11
    There is some gateway checkmark in the ethernet settings somewhere. Give that a try.
  • »17.06.26 - 18:56
    JohnFante
    Simply can not get it to work!
    I have tried setting the IP as static with the settings attached. Dobbeltchecking my router. And switching back and forth between DHCP and static with reboots in between.
    Settings like this: https://www.dropbox.com/scl/fi/7n1aohhjesrtr2vx37ucp/StaticIP.jpeg?rlkey=8lxfz34czolsllfxqdlorwsvk&dl=0
    @sailor: The right driver is chosen - as far as I can see.
    @skateman: There is a "gateway" setting on a second advanced page. Changes nothing.
    I was thinking of going back to the old driver from 3.19. Does that still work on 3.20?
  • »19.06.26 - 01:49
    Posts: 3328 from 2003/3/5
    Adding edebugflags=init to your boot parameters and capturing a log may help.
    Older driver should work just fine... assuming the problem is with the driver itself.
  • »19.06.26 - 13:50
    JohnFante
    Sorry for the noob question.
    Do I add: edebugflags=init in uboot? or?
    Ignore. Found this in another tread:
    setenv morphosargs EDEBUGFLAGS=init
    saveenv
    [ Edited by JohnFante 19.06.2026 - 18:55 ]
  • »19.06.26 - 17:52
    JohnFante
    Apparently I - or the update - had messed up some settings. Did a fresh renstall and now everything works again :-)
  • »23.06.26 - 08:06
