Posts: 1590 from 2012/11/9
Papiosaur - well I won't be testing it, well not right away, as
v3.20 is currently a failed release for my hardware iMac G5 A1145 - as it can cause my system to
totally lock-up/freeze, so I have to wait for the v3.20 to be fixed for my hardware until I am prepared to install it.
That is even though I was
incorrectly accused of being the likely
cause of the "freeze" with v3.20, due to some
residual files from the old Chrysalis Pack on my System partition. That has
now been proved NOT to be the case . . . it is the v3.20's release itself for iMac G5 iSight hardware that is the culprit - which is actually the
MorphOS Dev. Team's failure for releasing it . . .
not mine, when incompatibilites in the release still existed for iMac G5 iSight hardware !
I do not like being accused of such instances "out-of-hand/glibly", and then telling me, and I quote the words of
geit "You are on your own now," which was said without him even checking my observations for this release, as
geit is one of the MorphOS Development Team, and I would have hoped that he would have, at least, checked out what I had experienced as it was alarming for the system to "freeze" like that, just by playing an MP3 in the system supplied music player Jukebox!
As it turns out
I have proved that
the issue is in the v3.20 release itself, and . . .
not my system setup! I was quite
distressed that I was
treated with virtually no regard, merely due to some extraneous files that had been causing no trouble on my system for over 10 years. That said my system has now been cleansed of files that were residual, and unnecessary from that Chrysalis installation.
The trouble that needs cleaning is
the bug that has probably been created, not found, or been left
still in the v3.20 release by the MorphOS Development Team. So they may need to be your first betatesters, to ensure they don't go making the same mistake with the next MorphOS release!
MacMini 1.5GHz,64MB VRAM, PowerBooks A1138/9 (Model 5,8/9),PowerMac G5 2.3GHz(DP), iMac A1145 2.1GHz 20", all with MorphOS v3.19+,Airport,Bluetooth,A1016 Keyboard,T-RB22 Mouse,DVD-RW-DL,MiniMax,Firewire/USB2 & MacOSX 10.4/5
